1992 Camaro Transmission/clutch problem
Ville H. Valo
12-23-2003, 06:20 PM
Big problem, i will be driving and randomly i will lose almost all power, it is easy to tell that the clutch is slipping, but it was recently replaced, also, i recently bleed the clutch. anyways, it will go out, i will stop for a minute and then it will be fine again. do i need a new clutch or what?
1992 Camaro Z28 5.0 5 Speed
Ville H. Valo
12-24-2003, 01:54 AM
I was told this evening that it might be the hydralics in the transmissions, any input would be great.
90rocz
12-24-2003, 02:43 AM
That's a tuffy, a lot of things could've went wrong on the clutch job...but there's a good chance the master/slave cylinder is bad..
Not that hard to swap, and should'nt be too expensive.
You might see about getting a free estimate at a tranny place, then decide where to go from there.
Ville H. Valo
12-24-2003, 02:54 AM
that would cause it to diengauge and then it would work properly? i think the Hydralic arm sounds more resonable, but thanks for the input i will ask a tranny place
90rocz
12-24-2003, 03:27 AM
The problem is, the clutch is hydrolicly adjusted, master/slave cylinders...The internals of the trans has nothing to do with it..
