alum. head lt1---biggest valve
BIGCOWL-IMP
12-22-2003, 12:53 PM
whats the biggest valve you put in these heads
i have seen 2.02 in alum. and i have seen 2.055 in the irion lt1 heads.???
sleeperz28
12-22-2003, 02:12 PM
The valves on mine are 2.080 on the intake, 1.60 on exhaust. The afr 227's come with 2.100 on the intake, 1.6 exhaust
KCFormula
12-22-2003, 02:29 PM
IMHO if you are going to rev very high I would not go over 2.02/1.60s. When high reving engines dont have enough material between the valves that material can crack.
SSlammedlt-4
12-22-2003, 09:52 PM
I have 2.05/ 1.60 on my alum z heads.
bunker
12-23-2003, 03:22 AM
AFR227's have 2.08 & 1.6 just like my AFR220's that are laying somewhere in my room, screw them, I'm using LT1 heads for my NA setup :) maybe save these for my turbo setup, & the 383 laying around is for turbo aswell, sucks to be broke & have no job, but its awesome to have santa around :)
sleeperz28
12-23-2003, 01:06 PM
Better check again, they have the valve size on there site I believe. Because of the bigger valve the intake valve is offset requiring custom pistons for the valve reliefs
SStrokerAce
12-23-2003, 01:54 PM
I was going to say that.
With a bigger valve seat you can get a 2.08 valve in the LT1 heads.
Bret
jimlab
12-24-2003, 12:53 AM
2.10"/1.625" in AFR 215cc RRs...
http://home.gci.net/~jimlab/images/Heads/Completed/P1020025.jpg
bunker
12-24-2003, 04:51 AM
Hmm. mine are 2.08's I even measured them, they are AFR220's, I have a motor they aren't going in has 31CC dished SRP pistons, so that shouldn't be a problme for valve reliefs :)
