TwEaKeDSS
12-22-2003, 01:10 AM
My eagle 6in h-beam rods came with ARP bolts and I don't know where to find the torque specs for them? Anyone know :confused:
Torque Specs for Eagle Rods???TwEaKeDSS 12-22-2003, 01:10 AM My eagle 6in h-beam rods came with ARP bolts and I don't know where to find the torque specs for them? Anyone know :confused: GhostZ 12-22-2003, 01:29 AM This is all I could find bish. http://web.camaross.com/forums/showthread.php?s=&threadid=150366&highlight=torque+specs+eagle Oh...and this: http://www.bfranker.badz28.com/fbody/torquespecs.htm rskrause 12-22-2003, 05:04 AM Originally posted by TwEaKeDSS My eagle 6in h-beam rods came with ARP bolts and I don't know where to find the torque specs for them? Anyone know :confused: ARP's web site has 'em, I believe. Rich Krause TwEaKeDSS 12-22-2003, 01:11 PM Called Eagle this morning, 63ft lbs with ARP lube sleeperz28 12-22-2003, 02:19 PM If you have the 8740 bolt, the stretch is .063", and recommended torque is 60ft. However, when I assembled mine it took 72ft lbs to get them to stretch to the desired. What im saying is get yourself a rod bolt stretch gauge thats the most accurate. OldSStroker 12-22-2003, 07:30 PM Originally posted by sleeperz28 If you have the 8740 bolt, the stretch is .063", and recommended torque is 60ft. However, when I assembled mine it took 72ft lbs to get them to stretch to the desired. What im saying is get yourself a rod bolt stretch gauge thats the most accurate. Oops, that's .0063 bolt stretch, right? Bolt stretch IS the most accurate way to get the correct clamping load. TwEaKeDSS 12-22-2003, 08:41 PM Originally posted by sleeperz28 If you have the 8740 bolt, the stretch is .063", and recommended torque is 60ft. However, when I assembled mine it took 72ft lbs to get them to stretch to the desired. What im saying is get yourself a rod bolt stretch gauge thats the most accurate. I called Eagle and they said with the H-Beam rod #CRS6000B3D it comes with the ARP 7/16" capscrew bolts 190,000psi and the torque specs are 63ft lbs with arp lube :) sleeperz28 12-23-2003, 01:02 PM Originally posted by OldSStroker Oops, that's .0063 bolt stretch, right? Bolt stretch IS the most accurate way to get the correct clamping load. Yeah, yeah forgot a 0 that could have been a terrible thing:D Yes eagle claims this torque spec, but bolts dont always stretch proparly so thats why I use the gauge. however if you use the arp lube when torquing the bolts a majority of the time the bolts will stretch proparly. | ||
