ok this TBI = No performance
91 GTA Ramair2
12-21-2003, 04:38 AM
Yeah I Hate hearing people say TBI = no performance.
i've built a few awsome TBI engine's.
406TBI Meterail list:
1-forged crank large journal 8-sd forged 30over Keith black pistons, 8-sd forged rods, 8-sets of moly50/50 titanium rings, titanium bearing set: main rod cam, titanium gear drive set, stainless steal valve‘s.
406TBI Specs:
400Sbc .030pver bore, 10.5:1,292dur.575lift,Dart head’s, ported & polished, 2-400cfm TBI setup.
406TBI Dyno:
540hp@6500rpm
620ftlbtorque@5,000rpm.
Well it seem's to me I got performance form TBI :bow: ......
maybe your opion's might vairy.
I can throw up my spec's for my AMC390 Dual TBI engine too if ness. But i don't have the dyno for that yet cause it ain't done.....
:cool:
Kevin91Z
12-21-2003, 02:51 PM
Do you have pictures of this TBI engine? You mention "TWO" TBI units flowing 400cfm each, and of course that would make sense. A single TBI unit with two injectors is NOT going to flow enough fuel or air to make 500 horsepower. It barely has enough for 250 horsepower.
What computer are you using?
saiyanrage
12-21-2003, 09:52 PM
wow!Over 500 hp on a tbi?!?!?!?!:cool: :cool:
Now learn to spell!:D
91 GTA Ramair2
12-22-2003, 07:39 AM
yes over 500hp on a TBI.:bow: .
we used the Holley comander 950 computer.
the Hardest Part was Building the adaptor's to get the TB's to mount on the eddie 4x2 intake,But you could say i got my 1" spacer's done LoL.
i do have the injector spacer's as well.
so there prolly mor like 475 cfm each.
so 475cfm+475cfm=950CFM. witch should more then plenty "suport" the 540hp.........:bow: .
and i am more then plenty sure this 91 GTA Ramair2 will walk L-98's LT-1's and LS-1's.LS-6 ain't got nothing on me....
Just can't wait till summer whipping and LS-1 T/A then popping my hood and showing he lost to a "TBI" small block:cool: :bow: .
I do have my doubt's on the torque tho 620TQ seem's a bit high it's prolly only 520- 560 FTLB TQ but still more then plenty.
but we will find out when it go's in the 91GTA.
91 GTA Ramair2
12-22-2003, 07:46 AM
Now put all of this behind that nice 406TBI
CAR:
1991 GTA Ramair2
Transmission:
700R4: Heavy Duty internal's double clitched gear pack's,B&M Valve body,B&M filter shift improover,B&M front pump 12% volume ,7% more pressure,and over sized tranny pan Hold's an extra 2qt's (yippy skippy right??).
HD tranny cooler from a C-4500.
Diff/Gear's:
Msoer 9 inch rear end houseing Richmond 3.73 Gear's,
Jegs adjustable Lmiited slip diff.
Wanted:
295/50R16 Drag Radail's.
Ok Now For The Big Question??:About How Fast You Guy's Think I Should Run ??? Providing a good launch and traction. than About what it would really Run Providing an average launch and the usaul third gen traction lose???.
kevin 2.8
12-23-2003, 06:23 AM
instead of guessing what it will run, get a gtech, wait for the snowplow to go by and give it a boot up the street.
1994B4C
12-23-2003, 10:19 AM
I had a 383 with a carb making around the same power in an 87 camaro. My car ran 7.40's @ 94mph 1/8mi. My converter only went to 3600 and was way to tight. That was enough MPH to almost run 6.90's 1/8mi.
91 GTA Ramair2
12-23-2003, 12:17 PM
1. Car is NoT Assembold yet sadly.
2. I need them 295/50R16's Drag Radail's.
3. thnis car driven in winter are you crazy??.
Have Ran car's on a g-tech be fore not really trusting the reading's cause my 87 GTA L-98 should run 14.80's stock as i am told but according to G-tech it's only running 16.11's.
But the 91GTA on G-tech with a 350TBI,700R4,3.73 gear's ran 14.80's.
it was stock 350 tbi with 190,200miles and the 700r4 tho only had suposedly had 80,000miles,3.73 gear's had all 2,000miles.
it ran: 14.86@95.78Mph ( G-Tech ).I'm Hoping with avaerage third gen traction and street condition's
with the 406TBI it run's in the 12.40's.
But i'd be happy even if it only hit the 13.20's........
i am told by my power with good grip it should run mid to low 11's. From the local guy's.
Black6SpdTA
12-23-2003, 12:25 PM
Sounds about right. You figure ~320 rwhp is enough to push an F-Body to low 12's.
91 GTA Ramair2
12-23-2003, 01:50 PM
so you think it will run 12.40's on the street atleast ???
or you Agreeing with the Local guy's at the speed shop are right it Should run around the mid to low 11's???
Black6SpdTA
12-23-2003, 01:53 PM
Heavens no! 320hp is good for low 12's, so your 540 is def going to put you into the 11's, given traction. Low 11's.
91 GTA Ramair2
12-23-2003, 01:56 PM
Dyno: claim's the 406TBI has
540hp & 620TQ at fly wheel.:eek: I wish it was at the wheel's.
guy's at speed shop with the How i built say it's prolly more like,
530-560hp & 520- 580TQ@Flywheel.
cause that was the range most of the 406's they've seen with same spec's but they did say it might Be as high 620TQ cause of the EFI/TBI.
They say Put it in when car is Done and fine tuned he'll run it for free on there dyno tell me what i got at wheel's.:cool:
kevin 2.8
12-24-2003, 10:02 AM
good to know some out there have made good power with tbi, at least as long as ive been a member the drift was that tbi sucked and to stay away from it. that opens alot more options now for my next fbod, which must have t-tops and a v8
cant wait to see your results.
91 GTA Ramair2
12-24-2003, 09:37 PM
I know man I can't wait either i am so happy at how the engine came out.
i hope the rest of the car come's out as good.
I'm hoping it will run like 11.80's at union grove drag way,and like 12.40's on the street cruzin the Avenue/strip.
It's got a 4 core radiator for my trany cooling line's i ran a splitter and so the C-4500's tran's cooler is hook up as well as the radaitor's so am sure my beefy 700R4 will hold the load for the longest of all the 700r4's.
Cool tranny = solid shift's.
Car has T-top's so now i am going to conect the sub frame's so i have a ok solid body and i'll prolly never remove thr T-top's well driving it unless i am sure it will hold up.
I'm going to run the 2.5" true daul exhaust set up on it.
But with this setup i can only run my conector's front to rear I can use the "X" Looking setup withc is the strongest But oh well.
thought :
what if i drop the Front and rear section's of frame out and Duplcate them exactly sept the Rail's continue front so back.
where it would set just how it dose now But instead fo welding steal to each secetion what i would have welded on is ther all as one solid peice.???????
funina91ss
12-24-2003, 11:57 PM
91 GTA Ramair2 Did you have this motor dynoed? or is the power #'s just the machine shop guessing what it will make
:confused:
1994B4C 94mph sounds dead on for the mid 7's in a full weitght f-body. to run 6.90's you will have to have atleast 99mph.
91 GTA Ramair2
12-25-2003, 12:31 AM
the Dnyo said 540hp@6500 and 620T@5,000rpm i was watchin the meter while they ran it
i was just in doubt that i built something that good.
91 GTA Ramair2
12-25-2003, 12:32 AM
620FTLB seem's high for only a 10.5:1 C/R...
1994B4C
12-25-2003, 12:35 AM
funina91ss- No, a buddy of mine with about the same car, a little different motor went to the track the same night. He ran 7.1x's at 93. The difference was made in the 60ft, due to his converter.
