Need help figuring my spring rates
KeithO
12-20-2003, 07:47 PM
I bought a car that was already set up. The seller didn't seem to know the spring rates in the car and I am trying to figure them out for myself.
Relevant information:
This is a 4th gen Firebird with Ground Control Coilovers on the front. The rears have a threaded lower perch for the coil to sit in and the piece looks similar in color scheme as the front GC kits.
I just jacked the car up and looked...
The front springs are labeled Eibach and have the following numbers painted on them: 0800.250.0850 Are any of these numbers indicating the spring rate. There are no other markings on the springs.
The rears are completely unmarked gray, steel coils. Top-to-bottom, they are 9.25" tall...
Any ideas?
Jon A
12-20-2003, 09:03 PM
The numbers for the front mean it's an 8" long, 2.5" ID spring. The last number is the rate, 850 #/in.
No way to tell what the rears are without some detailed measurements.
94bird
12-20-2003, 09:20 PM
Keith, Jon's right about the front spring rates. Damn, that's a Global West type of spring rate. Thinking about using that 35mm sway bar on the front of this car too?
My rear springs also don't have a rate on them. I don't think any of them do. Luckily I bought mine from a local autoxer that had them in the original boxes. You could always measure the free height, then set a known weight on top of one of them and measure how much it compresses. Not sure there's much else you can do.
KeithO
12-21-2003, 06:44 AM
I figured these were stiff springs.
This has caused me conclude that I should call the previous, previous owner today. I have a couple of other questions about the car and he clearly was the one who did the setup, etc.
sgarnett
12-21-2003, 09:22 AM
I posted the spring rate equation in your post on ls1.com. It is important to get a very accurate measurement of the spring wire diameter though.
lons94z
12-21-2003, 12:20 PM
