Feeling the need to stroke it? Lunati kits inside!
tbyrne
12-20-2003, 03:02 PM
Lunati currently has 14 different LS1 and LS6 rotating assemblies available and they will have two new kits coming soon. The Lunati engine assemblies are made with the finest Lunati engine components, including a Lunati Pro-Series crankshaft, Lunati Pro-Billet connecting rods, Lunati forged pistons, rings, bearings, and piston pins.
If a turbo or blower is to be used, they recommend 8.5 CR with pump gas. For racing and race fuel you can move to 12.5 CR for maximum performance. The pistons and rings come in 0.005" oversize to accommodate honing to clean up the cylinders. The top ring is a 1.5 mm moly plasma pre gapped ring, second ring is 1.5 mm cast-iron reverse-twist, and the oil ring is 3 mm three-piece. The assembly is internally balanced and the reluctor ring is installed. All this, and with your choice of up to 408 cubic inches!
We are offering discounts on all of the Lunati stroker kits and cams that they produce. Pistons, rods, ect... can also be purchased seperate. Pricing is available by e-mailing tbyrne@tbyrne.com or give Julie a call at 1-508-678-2071 Monday - Friday.
Have a good day!
Tom
Cmr0z28
12-20-2003, 05:15 PM
"Feeling the need to stroke it?"
HAHAHHAAH LMFAO!!!!!!!!!
tbyrne
12-22-2003, 10:00 AM
Like that one huh! :)
The new LS1 kits are -
EA035-427 LS1 Engine Assembly 427CID 10.6:1
EA035-434 LS1 Engine Assembly 434CID 10.6:1
EA035-447 LS1 Engine Assembly 447CID 10.6:1
EA135-427 LS6 Engine Assembly 427CID 10.6:1
We're also working on a list for the LT1 cars.
Cmr0z28
12-22-2003, 02:56 PM
Originally posted by aggiez28
gonna run a gp on ky jelly?
brook
ahahhah ROFL
americanmusscle
12-22-2003, 04:01 PM
Stroking it and ky jelly all in the same thread. hahahahahahahahahahahahahahahaha
Oh yeah then theres the stroker kits :eek: Niiiiiiiiiccccce.
tbyrne
12-22-2003, 08:54 PM
These kits aren't listed on the site yet but they are available -
LT1 Engine Assemblies
EA040-383A
9.5:1 - 64CC Heads Automatic Transmission
10.1:1 - 58cc Heads Automatic Transmission
10.5:1 - 54cc Heads Automatic Transmission
EA040-383B
9.5:1 - 64CC Heads Manual Trans - Single Mass Flywheel
10.1:1 - 58cc Heads Manual Trans - Single Mass Flywheel
10.5:1 - 54cc Heads Manual Trans - Single Mass Flywheel
EA040-383C
9.5:1 - 64CC Heads Manual Trans - Dual Mass Flywheel
10.1:1 - 58cc Heads Manual Trans - Dual Mass Flywheel
10.5:1 - 54cc Heads Manual Trans - Dual Mass Flywheel
EA040-385A
EA040-385A
EA040-385A
Just call or e-mail for pricing.
Tom
GhostZ
12-22-2003, 11:17 PM
Sent you an email.
