Difference between M21 and M22
S.J.S.
12-19-2003, 08:50 PM
How can you tell the difference????
angel71rs
12-19-2003, 10:07 PM
Only way to be sure is to look at the gearset. This site compares the M22 gears to M20 gears (same as M21 except for ratio):
http://www.gearzone.net/muncie3.htm
Tim H
12-20-2003, 09:09 AM
I think on the imput shaft there is single ring around it for a M21,double for a M20 and no ring for a M22.
91 GTA Ramair2
12-22-2003, 05:23 AM
only real mjor differnce is the M-22 is heavyer built then the m-21
The M-22 in the Rock Crusher after all.
MSM69Z28
12-22-2003, 08:18 PM
m22 is a straighter cut gear than the M20 and 21. straighter gear cuts can tolerate more power. jerico and other big name trasn builders often use straight cuts gears and m22 i think is cut at a 45. m20 and 21 are more, but i don't remember how much.
91 GTA Ramair2
12-23-2003, 12:11 AM
So the m-20 M-21 or the M-22 Rock Crusher???
bgreenard
12-23-2003, 01:50 AM
The M22 is the "Rock Crusher" because of the whine of the straighter cut gears. It is stronger than the M20 wide ratio and M21, but it is not indestructable. I know! I have destroyed them all. The Super T10 is just as strong IMHO as the M22 even though I have broken that one too:)
91 GTA Ramair2
12-23-2003, 02:18 AM
Well Cool stuff the AMX has the Crusher....
