90rocz
12-18-2003, 02:11 AM
Is it possible to change my 1st gear ratio to like 2.75 similar to a 2004r??
Can I change my 1st gear ratio in my 700r4?90rocz 12-18-2003, 02:11 AM Is it possible to change my 1st gear ratio to like 2.75 similar to a 2004r?? Pro Built Automatics 12-18-2003, 05:01 PM There are no after market gear ratio changes for the 700R4/4L60E. If you use the right torque converter, you can hide the big rpm drop on the 1-2 shift. 90rocz 12-18-2003, 11:40 PM Thanks, I have a SLP 2400-2600 convertor.. Is the 2004r gear set interchangeable?? Pro Built Automatics 12-19-2003, 02:25 AM There is nothing interchangable between the 2004R & the 700R4/4L60E. 90rocz 12-19-2003, 01:47 PM How is changing gear ratio's accomplished in automatic transmissions, swapping the entire Planetary set??? | ||
