Heatmaker
12-17-2003, 05:55 PM
Can't find the Torque wrench with the dial on it. Went to just about every place! Can't find it at all...is there a trick are anything I can do to set the preload without using that device?
Also what's a good trick to getting the Backlash right?
my94blackz
12-18-2003, 12:09 AM
did you buy a new crush bearing? if so have fun if not it should be pretty easy. reach up and grab the thing where the driveshaft bolts in and if it moves back and forth tighten some more. how did ya backlash pattern look?
Heatmaker
12-18-2003, 01:57 AM
Yeah, I got a new crush sleeve...I understand you have to do what...torque it to hell right...?
my94blackz
12-18-2003, 03:17 PM
It takes alot to crush one and i mean ALOT. We took a monkey wrench to hold the piece where the driveshaft connected to hold it still then used a 3 foot bar. It takes alot. Just make sure your cant move it back and forth.
