New tranny for 02 LS1
QuickSilver02
12-15-2003, 07:28 PM
Anybody have suggestions for new transmissions on an 02 LS1? I need something that can handle 6500 RPMs and I can't find squat on the Internet. Please help me!:cry:
Gloveperson
12-15-2003, 07:33 PM
manual or automatic?
QuickSilver02
12-15-2003, 07:35 PM
automatic
Capn Pete
12-15-2003, 09:03 PM
GM now builds a 4L65E instead of the regular 4L60E.........apparently it comes in Avalanches or something?:think: Regardless, I read an article in a magazine about them, and they're pretty much a 4L60E with upgraded internals, such as stronger input and output shafts, heavier duty clutch packs, and stronger planetary gears (or whatever the heck are used inside automatics?!:p). I'm sure that you could just build up a 60 to what the 65 is, but to save the trouble, you can simply buy a 4L65E and be done with it:cool:.
HTH
QuickSilver02
12-15-2003, 09:36 PM
Are there any race transmissions or anything like that out there specifically for the LS1?:confused: I'll be pushing close to 420 rwhp and need something that can handle that kind of power. I don't think the stock tranny can handle that.
psychocabbage
12-15-2003, 10:49 PM
I went through 6 4L60E's so I know they are junk.. Ya can go TH350 or 400 and be done with it. .but ya will have a manual valve body most likely..
Get it done right tho.. no sense in wasting $ on a motor that cant be used..
AL SS590 M6
12-16-2003, 03:31 AM
They are not all junk. The ones that you had were, but that doesn't mean they all are.
I have over 500 passes on my stock one with 200 of those passes with a high stall and slicks. Oh and that's pulling 1.64-1.75 sixty foots and running low 12s at 110 plus. Not junk.
Many companys build 4l60e transmissions that claim 500-650 hp capabilities. But I can't and won't recommend any because I have no personal experience yet.
Check out the vendor index. Speed Inc and some other supporting vendors have built transmissions for sale.
boomcase
12-16-2003, 12:28 PM
Century transmision.
Knowklew
12-16-2003, 12:30 PM
http://ls1speed.com/catagory.cfm?catagory=trans
These should help or give you an idea of what is out there.
QuickSilver02
12-16-2003, 04:29 PM
Thanks. That website really helps!:thumb:
psychocabbage
12-16-2003, 10:18 PM
the harsh hits on the tranny are on thing.. the repeated 140+mph runs with 110+ sustained for over 35 min at a time... daily.. (to and from work) not the same thing... and thats what was killing my trannys.. And yes, I had a cooler on it too..
