dnz28
12-15-2003, 06:39 PM
I was wonder if the chevy 305 is a chevy 350 with a smaller crank? And different heads? Cause I found a good deal on one for 100 bucks running
chevy 305dnz28 12-15-2003, 06:39 PM I was wonder if the chevy 305 is a chevy 350 with a smaller crank? And different heads? Cause I found a good deal on one for 100 bucks running angel71rs 12-15-2003, 09:30 PM 305 has same stroke as 350, but a smaller bore. Heads have smaller chambers (58-59cc common) than 350 heads (76 or 64cc). 305 is a decent engine for a grocery getter, and can be built to make good hp, but a 350 is a better starting point. jays76camaro 12-23-2003, 10:12 AM My stock 305 in my 76 was rated 140@2800 I yanked that out immediately for a 350 94m5 12-27-2003, 02:01 AM Originally posted by angel71rs 305 has same stroke as 350, but a smaller bore. Heads have smaller chambers (58-59cc common) than 350 heads (76 or 64cc). 305 is a decent engine for a grocery getter, and can be built to make good hp, but a 350 is a better starting point. In addition to that.....Many people try to put 305 heads on a bigger Smallblock to raise the compression. This WILL raise the compression But will reduce air flow due to smaller valves. Unless you NEED a running engine I would pass this deal up. The larger bore blocks are the way to go. Mike dnz28 12-27-2003, 11:27 AM i have a working motor i just thought for a 100 bucks it wasnt a bad deal just tring to learn something about before i would purchase it. i didnt buy it though. FiberglassBlues 01-05-2004, 11:55 PM Sure did sound cheap enough! But im like everyone else more cubes the better:cool: killer-camaro 01-06-2004, 12:34 AM actually the 305 (i'm assuming you want the Z/28 engine) is a 283 block with a 327 crank. you could aslo accomplish this goal by finding a small journal 327 and putting in a 283 crank. BIGBADBOWTIE 01-06-2004, 09:53 AM ACTUALLY...... the 305 is not a 283/327 combo..... the 305 has a 3.740 x 3.48. The 302 which was the 67-69 z motor was the same bore as a 327.. (4.00) and stroke of a 283...(3.00) Just wanted to add that. bowtie-70 01-06-2004, 01:02 PM Originally posted by killer-camaro actually the 305 (i'm assuming you want the Z/28 engine) is a 283 block with a 327 crank. Thats the 307. nape 01-06-2004, 02:51 PM Originally posted by bowtie-70 Thats the 307. Wrong again. 307 was a 3.875" bore with a 3.25" stroke. 327 with a 283 crank is a 302. Here's a page that lists SBC specs: http://www.dumpit.org/grimreaper/sbc-engspec.html bowtie-70 01-07-2004, 09:11 AM 307 = 283 bore & 327 stroke 302 = 327 bore & 283 stroke 305 = unique bore & 350 stroke (had the smallest bore & longest stroke) | ||
