1996 | Z28 SS
12-13-2003, 10:42 AM
I've only ever used my Zaino is the summer so far... but now it's winter.. it's actualy -10 outside (celcius of course.. so thats what 14 *F?) anyways... is there any negative effects to using Zaino is this kind of temperatures beside it will probably take forever to dry? Right now the suns out and I'm thinking I'll bare the cold to get a good coat on. Thanks
Trevor
Brent94Z
12-13-2003, 11:30 AM
Moving to the Show and Shine forum...
KevinSS
12-13-2003, 03:09 PM
I have never applied it lower than 32F , since you are taking it to the extreme, I really do not know. You might want to email Sal, I would think that the polish might freeze solid at 14 or 15 degrees.
1996 | Z28 SS
12-13-2003, 05:11 PM
Well... I waxed her up already.. :D No problems what so ever. Well.. actualy, now that I think of it.. the last bit of wax that I was rubbing off seemed to be slightly harder.. not much though. Just took a little extra pressure. And I also sprayed on the Z6 afterwards.. was a little tricky because if I put too much on at once.. it very, very quickly froze/dried right up. So I just took a little extra time.
Zaino = The best :cool:
Trevor
hcvone
12-15-2003, 08:17 AM
I know someone that had it freeze on their car, it was a mess and had to be washed off several times to remove it, if you had no problems you were lucky.
1996 | Z28 SS
12-16-2003, 06:50 PM
hmmm... how long did he let it dry for? And how cold was it?? It was -10 but the sun was out.. so through out the day it probably got up to -5 and was even warmer in the sunlight directly. Maybe that helped.. but I didn't let it sit too long... 20min maybe. And nothing froze at all.. not as easy to take of as it is during the summer of course but not by much though...
Kevin V 2002 SS
12-17-2003, 07:12 PM
If you were in sunlight that helped warm up the body a little. Personally, I'd recommend staying on the 32*+ side just to be sure AND use the ZFX to help the drying due to the lower temperatures.
Drumhawk
12-18-2003, 08:17 AM
Trevor I don't think it's a good idea unless you drive your car through the winter. :no: My hawk is off the road for the winter in my garage. I open the door into the house connecting the garage to warm it up before I apply zaino. Just my opinion from a fellow canuck. :thumb:
94bonefast
12-19-2003, 12:48 AM
B]I open the door into the house connecting the garage to warm it up before I apply zaino. Just my opinion from a fellow canuck. :thumb: [/B][/QUOTE] [/B]
Yeah the old lady doesn't like it when I do that trick.:rolleyes:[
Drumhawk
12-19-2003, 02:59 AM
Yeah the old lady doesn't like it when I do that trick.:rolleyes:[ [/B][/QUOTE] I don't have an old lady and if I did she better not tell me to waste heat in the garage. I'll pay the extra few bucks hydro no problem. BC has one of the lowest hydro rates in North America and there hasn't been an increase in ten years but they want one now. :shock:
Big Red Jim
12-25-2003, 04:45 PM
I think 20* F is about as cold as I've ever applied Zaino. If I recall, it took nearly an hour to dry.
