Making the Stealth Ram emissions legal
I'd love a Stealth Ram. Basically because they're cheap and pull like crazy up top and only $300 from Summit. But where I live, we have to pass emissions sniffer/visual. Is all that the HSR is missing is EGR? If so, is there any way to route the factory, or even aftermarket, system to the HSR?
-Corey
-Corey
I know the TPI corvettes had a different setup than the camaros. I think it was mounted on one of the exhaust manifolds and used a set of tubes to route the recircularted gas back in.
I think pics would help, anybody got em? I want to do the same thing.
Here is how I did mine on my Corvette heads:
http://para.noid.org/~thresher/image...1&dispsize=800
However, the Holley Stealth Ram doesnt have a port for EGR. There isnt a way to add it that I know of.
Originally posted by Rippin92RS
Couldn't you just drill/tap a hole for the line coming from valve to intake?
And even if you did make it work, its still not smog legal because Holley didnt certify it that way.
Take a look at how a stock one does it and then see if you can recreate it. I know I cant. Where are you going to mount the EGR valve and solenoid? How are you going to drill into the intake to add the exhaust gas?
-Corey
Really, How long does an intake swap take? I never really did understand you emissions people
I could do an intake swap in a matter of hours. Just go get the sniffer done with the TPI on there, come home, take the afternoon to put the HSR back on. I'd do it, but I don't have to.
In the parts of Pa where there are emissions 95 and older are only visual and if the car/truck is driven less than 5k a year it's exempt. My Iroc only has 11k in 3 1/2 years and i myself have been thinking of doing that swap.
When you modify the intake to work on a Gen 1 SBC, you have to get rid of the EGR system.
Sorry about that.
I think I'm getting a datamaster for xmas. I hope I hope. But after Xmas, I'm going to pick up my new, used LT1 block. No emissions here either, thank God.
