subframe connecters-advice?
oldschoolfella
12-04-2003, 07:18 PM
i am currently restoring an '81 z28 with t-tops, and i believe it has sagged badly, as the tops leak and the doors sag badly. i heard installing subframe connectors is the first step to rectifying yhis problem, since t-top models were prone to these problems. if you have any advise, or know anyone who can help me with this, especially in the ne tn area, please let me know. your help is greatly appreciated!
kacy
12-04-2003, 07:36 PM
ttop seal leak with age and door hinges wear out so dont jump to that conclusion unless you have already replaced them
there are mixed emotions bout them i had bolts on my 97 never had a problem with them
Erik
12-04-2003, 09:23 PM
Replace the door hardware to fix the sagging doors.
If your car is cracking where the corner of the side windows meets the roofline, it's sagging.
If you do get sfc's, get weld in.
Greed4Speed
12-08-2003, 10:49 PM
Bolt ons work fine. There are several guys in the LS1 section that race autocross w/bolt on SFCs. Think about it, your suspension is bolted on...why wouldn't it loosen up like some people claim bolt on SFCs do?
Personally, I'd use which ever I got the best deal on.
Dirt Reynolds
12-08-2003, 11:02 PM
I have welded-in SFC's, would not have it any other way. Mine are actually custom made by the fabrication shop which installed my 4130 8-point cage, and what they did was actually cut the floor out and weld the square-tubing stock of my SFC's to both the top and bottom of the floor, all the way front to rear. They were also welded in to the front and rear subframes. Let me tell you, this is one stiff car chassis. I've owned 3 2nd gen Z/28's, and my '77 with the above mods is by far the best riding and launching car of the bunch.
Welding in SFC's makes them a permanent part of the frame assembly.
:cool:
2x4
12-09-2003, 05:38 PM
Be sure you replace the body bushings before you weld in the sub connectors.
jg95z28
12-09-2003, 06:41 PM
T-tops have always leaked. Hinges typically wear out causing the doors to sag. (Considering how big 2nd gen doors are... who can blame those poor hinges.) Unless there are severe flex problems with the unibody, don't neccessarily assume subframe connectors will fix the problem.
