what kind of 60 foot do yall pull
imyeepeepaw
12-03-2003, 07:27 PM
i pull a 1.73 on motor and a 1.59 on gas is that good for an ls1 and has anyone used a 373 gear in one
MISOMWS6
12-03-2003, 09:31 PM
What mods do you have?? M6 or A4?? If you are a lightly modded LS1 M6 those are good times. If you are an A4 with a decent stall and a few little mods than they are ok, I would say good if you were on stock tires. How big of a shot do you spray?? Also what kind of tires do you run?? NEED SOME MORE INPUT:D
rncotton
12-04-2003, 11:47 AM
2001 WS6, M6 tranny, 4.11 rear
Defender Tires (Generic Michellin) -- 2.1 60' time, stock LCAs
Kumho 712's -- 2.1 60' time, stock LCAs
Kumho 712's -- 1.9 60' time, Boxed LCAs from Spectacle Solutions
kcsoz20
12-04-2003, 07:53 PM
Best 60' is 1.67 which is with 3.73's, 2800 stall and Hoosier QTP's, flashing the stall.
Ken
LS1_03
12-04-2003, 08:37 PM
94 Z28 with just a cat back, 160 thermo, 1LE elbow and Firestone Firehawk SZ50EPs I netted a 2.092 60' stalling to 1500. 2.73 gears I might add.
imyeepeepaw
12-04-2003, 09:48 PM
my car is an a4 with a 2800 stall and 323 gears tires are 26-10.5-15 i run a 125 shot an slp air lid and borla exhaust
formula383
12-04-2003, 10:53 PM
My car pulled a 1.69 on Nittos. Thats with lowering springs (not good for traction), 3200 Vigilante.
Robert95z
12-04-2003, 11:38 PM
1.9s with 2.73 gears:)
95Bird
12-04-2003, 11:45 PM
1.48 with a 6 speed and NA.
nd4spd200
12-05-2003, 12:03 AM
1.51 with a 6 speed N.A. still has room for improvement
HungryT/A
12-05-2003, 05:31 AM
Holy crap, those are some nice sixties, you M6 guys!
I cut a 2.32 with Toyo's, 2.20 with ET Streets! (M6) I really don't know...does track preparation (VHT) make sooo much difference?!
We're runnin on asphalt here...
rskrause
12-05-2003, 07:28 AM
I haven't figured out how to launch with the TH400 yet.
But with the M6, 3.42's, 16" ET STreets and a stiff, high performance street type suspension I pulled a best of 1.51sec. With the TH400 and a 15" QTP my best was 1.62sec. But I think a high 1.4 time should be possible even with my drag unfriendly suspension setup.
Track prep makes a HUGE difference.
Rich Krause
Javier97Z28
12-05-2003, 08:50 AM
Track prep makes all the difference in the world.. been lucky that my local track has gotten up much better about that.
1.7's on Nitto's and a 2800 Vigilante with stock 3.23's.
I'll be giving my 3.73's a shot tonight.
Ken95Z28
12-05-2003, 09:00 AM
1.49 best 60' :D
95Bird
12-05-2003, 10:12 AM
Track prep makes a big difference. so do suspension mods on a 6 speed. While the auto guys can get away with a stock suspension and still cut descent 60s...m6's can't.
Jilly
12-05-2003, 11:25 AM
A consistent 2.1, and that's when my Z was stock.
90rocz
12-05-2003, 02:08 PM
1.865 best, avg. 1.90's..Street tires, Lakewood LCA's & adj Panhrard rod, Urethane bushings, KYB GR2 Shocks & Struts, functional sway bars. Still spin pretty bad too...:(
Derrick Redd
12-06-2003, 12:00 PM
Best of 1.55 so far. :cool:
94_Z28_ragtop
12-06-2003, 12:04 PM
1994 Z28 = 1.68 running N/A on 26 x 10 E/T Drags A4 w/Vigi 2800
2002 Z28 = 1.84 running N/A on 26 x 10 E/T Drags M6 stock clutch & 10 bolt
big dave
12-06-2003, 11:13 PM
My 94 auto has pulled 1.64 60s on nittos. My 99SS 6 spd has pulled 2.00s on street tires.
kevkop94TA
12-07-2003, 03:39 PM
1.75 here. A4 2600 stall, BFG DR's, !swaybar and the usual bolt ons. Its consistently in the 1.8's, with the occasional 1.7
94ZRiCeKiLr
12-08-2003, 12:40 AM
consistent high 1.6s with a 3400 stall and a 3.42 gear on a 17 inch Drag radial....best is a 1.66....the car has the punch to go low 1.6s on a sitckier tire.
hotrod 95
12-08-2003, 06:30 AM
1.44:D
red
12-08-2003, 11:37 AM
1.52 with a M6 and N/A. I don't have any N2O 60' times yet.
1fstTA
12-08-2003, 03:46 PM
1.38 with a small 125 shot looking to better it now that ill be spraying atleast 200-250
96LT14u2Nv
12-10-2003, 10:34 PM
1.71 is the best with 26x11.5" ET streets on salad shooters with BONE STOCK suspension and 3.73's and 3200 Coan stall
KEITHZ06
12-12-2003, 08:42 AM
Best so far 1.428 still shooting for 1.30's need to make some more chassis adjustments.
ltlhomer
12-16-2003, 08:53 PM
Consistent mid to low 1.6's. Bone stock suspension at the time.
Next year should be better w/ the th400 (tbrake), bmr T/A, bigger stall and a few other goodies. Maybe low 1.5's / high 1.4's or so.
hotrod 95
12-16-2003, 08:59 PM
Just changed mine this weekend to a 1.41 on the motor
87Z
12-16-2003, 09:06 PM
my best is 2.2 my worst is 2.3 I guess thats pretty good for what I have, completely stock suspenson with a LG4, 700r4, and 2.73 open
91 Redd Sledd
12-17-2003, 02:49 PM
2.0 on Goodyear GSC's and 305 Cubic inches pushin it;) A4,and Eibach lowering springs,3:73 gear and Convertible.
1.70's in my Mustang with ET Streets and stock suspension, 5 speed,3:55 gear and also convertible
James
bad93z
12-17-2003, 04:28 PM
2.0 with !frontswaybar, eibach drag springs, Kelly charger tires (horrible!!) stock stall, and 3.23's
