Bad Vibration
Old Dec 3, 2003 | 01:33 PM
1FstFormulaV8's Avatar
Bad Vibration
I'm having a BAD vibration around 1000 rpm. The vibration shakes the whole car. You can have it idling and visually watch the exhaust just shake. It's even worse at 50 mph. The whole car shakes. Put it in neutral at speed, no vibration, put it back into gear, vibration returns.
Motor mounts?
Tranny Mounts?
Old Dec 3, 2003 | 01:49 PM
Heatmaker's Avatar
Advanced Member
Driveshaft
Old Dec 3, 2003 | 01:55 PM
Before it started this. I would sometimes here a loud cracking noise. Drive shaft? Even if I can watch the motor and exhaust shake in park?
Old Dec 3, 2003 | 02:23 PM
Heatmaker's Avatar
Advanced Member
I'm just thinking becasue most driveshaft vibrations happen when it's in gear. And the DS vibrations are pretty strong. Usually they'll stop when in neutral. Since the DS is not engaged. But when you say the car is in park and it's shaking the only thing still spinning is the Flywheel. So that my lead to something going on in the clutch area.
Old Dec 11, 2003 | 01:37 PM
kgkern01's Avatar
Actually, anytime the car is moving, the driveshaft is moving, putting the car in neutral will have no effect on an out of balance driveshaft. The car in neutral only means that the gears in the tranny are not engaged, however the rest of the drivetrain is still moving. The clutch does not engage the driveshaft, it engages the trans input shaft, which engages the gear, turning the output shaft, to driveshaft, to rear end, etc. So if the vibration goes away with the clutch pressed, it is not a DS problem, it is a clutch/pilot bearing/tranny problem.
Old Dec 16, 2003 | 12:34 AM
pvkn1ght's Avatar
I'd check the motor and tranny mounts if you get a lot of shaking in idle. From what I've read and from my own experience, driveshaft issues usually begin at a certain speed and up; most commonly around 75-80mph+ My driveshaft vibe started at 82mph and got progressively worse; car shook from what felt like was the radio/centerconsole/shifter area
if that's any help Brian
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
