New best for the LT1 91 RS
slimdawson
11-29-2003, 01:28 AM
Ran a couple of weeks ago and just getting around to posting.
Anyway, my 60 was around 2.1. I went through at 13.12@112. I am running into some false knock powershifting so I lost some mph in the 1/8 but it picked it all up after that. I expect my times to go down but my mph to stay the same once I get that worked out. My laptop is going nuts so I haven't been able to tune.
My best nitrous pass was that night as well. I got a 12.3@120 with a 60 around 2.1 as well. I am spraying a dry 100 shot although it is only getting about an extra 80 to the wheels according to the dyno. The car is way rich at around 10:1 - 11:1 afr on the spray. That would be the cause.
It is only a bolt on motor and still retains the stock pully, air flow meter and throttle body. It still has the stock timing in it. I would love to put a tb and a mass air flow sensor on it and jack up the timing. Until then I will try to hook it a little better and shoot for 12s.
Later, Mike.
scott9050
12-01-2003, 02:50 AM
Pretty impressive 3rd gen you have there:)
LSs1Power
12-01-2003, 02:52 AM
Nice, U have a 12sec car there if u can get a 2.0 60ft at the least. now update ur Sig. :)
slimdawson
12-01-2003, 02:28 PM
Thanks guys.
I actually ran a low 12.9 according to the g tech. When my buddy runs the g tech at the track the et is consistent with the clocks. I do hook better on the street than at the track I went to.
Later.
