Bad paint. What to do???
mavricki18
11-27-2003, 10:45 PM
I have a hugger orange camaro and the paint is looking dull and it has a lot of swirl marks in it. I have not polished or waxed it all summer. I fuiger it will be a good winter project to do. What products should i use to restore the shiny color and get rid of the swirl marks?
GreenGobbler
11-28-2003, 01:26 PM
Hey man Check out the rubbing compound thread that will help get your paint back to norm.:D the porter cable orbital is a good tool to use if your not comf. with a high speed buffer hope this helps :D
KevinSS
11-28-2003, 01:52 PM
Wash with Dawn, Clay Bar entire car, wash again, dry, use 3M Swirl Mark Remover part number 39009 preferrably with a foam pad and orbital buffer, bufff only sections at a time and remove the 3M before dry, re wash entire car with Dawn after each section is 3Med, then apply Zaino Z-5 swirl filler system.
mavricki18
11-28-2003, 06:35 PM
Thanks for the help guys i just happen to have the 3m swirl mark stuff. The buffer and zaino stuff will make a good x-mas present.
What zaino polishes and waxes do you recommend for use afterwards?
KevinSS
11-28-2003, 06:42 PM
We have two polishes, the Z-5 for filling swirls and the Z-2 for super high gloss, you will need also the ZFX activator to along with these and the Z-18 Clay Bar unless you already have the clay bar. But most of my customers are ordering the new ZKIT-1 that has all you need, the Z-2,5,6,7,18, ZFX, and three applicators.
Here is tip, you can now purchase the Porter Cable Orbital buffer with correct 6 inch counter weight already installed at Lowes for 109.00 and get all your pads from www.topoftheline.com
Lt1 and Ls1
11-30-2003, 03:00 PM
Thanks for all the helpful info. I have never used zaino before but have heard many good things. Definately getting some!
