New Best ET....Any Guesses What She'll Run On Spray??
COMNBYU
11-27-2003, 10:42 AM
Ran my car last weekend after we finished up the mods in sig. First pass out was a 12.73 @ 105.86. Next pass was a 13.30 @ 105.35 hitting the rev limiter in 2nd and letting off for a second. Last run was eliminations, went a 13.21 @ 95.01 all over the brakes trying not to brake out, but doing so anyway.
Best 60 on the first run was 1.81. the others were 1.96 and 1.90. Im still practicing with my launches. I wasnt really agressive with the stall and am still working on the best way to launch the car. I think with a little better 60, I might be able to see mid 12s.
These passes were NA btw. If I can find a truck to pull the trailer I borrowed with, Ill be going to Maryland this weekend for their last T&T this Sat. to try it on the spray....
Jon
RacinLT1
11-27-2003, 11:08 AM
how much do you plan on spraying it? what tires/suspension?
COMNBYU
11-27-2003, 03:15 PM
Ive been running it on spray. But before it was when the car was pretty much stock save for CAI/exhaust. Ive been running a 150 wet shot for a while. Best previous pass with a slipping tranny and 2.73s (and everything else stock) was 12.10 @ 115.
The only thing done to the susp. is taken off the FR sway bar. Everything else is stock. I run Pro Stars with skinnies and a ET street for everywhere I go.
It should be DEEP in the 11s...
Jon
MBonZ28
11-27-2003, 05:24 PM
no reason you shouldnt snag at least a 11.5 @120
PNYKILR
11-28-2003, 01:16 PM
I agree, 11.5's are doable. Good luck
RacinLT1
11-28-2003, 01:18 PM
stall is gonna be a lil tight for nitrous. but i dont see 11.3-11.5 being a problem,IF it hooks.
