Turbo, SuperCharger, or Heads & Cam ???
Rice Eater 316
11-24-2003, 05:40 PM
I was wanting some input for the best route to get my 2002 Camaro Z28 M6 up to about 450-500 HP. This is my baby and my daily driver as well so it will be 99% street driven as there isn't really a good track around where I live. I don't want to have to rebuild the engine, would like to leave the bottom end stock for $$ reasons. I've been considering either a Turbo kit, a Procharger Kit or just getting a good Head/Cam kit. Any opinions/suggestions will be greatly appreciated :)
I have a K&N FIPK on it as well as a Corsa Cat back. Also I believe the car was tuned with a Hypertech. In the future I'd like to at least put headers and Y-pipe on it as well to finish out the exhaust.
Thanks in advance :bow:
93formula
11-25-2003, 12:09 AM
how bout a sts kit?
http://web.camaross.com/forums/showthread.php?s=&threadid=196767
509 rwhp and 550 rwtq on a stock ls1.
Chris B
11-25-2003, 12:15 AM
If you don't want to touch the bottom end/worry about rebuilds I would just suggest a decent heads/cam setup.
Chris
93formula
11-25-2003, 12:37 AM
yes on a ls1 HC packages cant go wrong either.
96 WS6
11-25-2003, 04:43 AM
Originally posted by 93formula
how bout a sts kit?
Do you work for STS or do you just suck their dicks??? You rep them like they are paying you.
Get heads and cam, boost on stock bottom end can be dangerous and if you don't want to spend the loot, don't do it.
rskrause
11-25-2003, 08:56 AM
How much can you do yourself vs. pay someone else to do? I am not a big fan of boost and a stock bottom end. However, the LS1 respons amazingly well to even small amounts of boost. You will see over 450rwhp (for an M6) with just 6lbs, which is relatively safe. There is a huge potential advantage, as a SC install is a pretty easy job, not so for heads and cam. Most people can do the blower themselves. OTOH, total cost if paying someone to do the work will be about the same with heads and cam v. a centrifugal blower. The higher cost for parts with the SC will offset the greater labor for the H&C.
I don't know anything about the available turbo kits, so I have no comment on that one.
Rich Krause
93formula
11-25-2003, 08:29 PM
hey dip****, im buying one and two of my friends are buying them as well, why do you care if i like to spread the word, lots of people here hype combo, go pick on them.
its a good system that now has dyno numbers to back it.
i wish they were paying me
kgkern01
11-26-2003, 06:18 PM
I don't trust the rear mount of the turbo, especially with the air filter under the car=water+more dirt. Plus the lag associated with the amount of piping the system has to go thru and pressurize, as well as the exhaust. I would say it would be worth it to go with a front mounted turbo system, unless it is more for the novelty value or you like the easier install/removal of the system.
engineermike
11-26-2003, 07:28 PM
Heads and cam will be more reliable, worry-free, less prone to detonation, less moving parts to break, etc. . .
Plus, a car making 450 hp NA is more impressive (to me, at least) than a car making 450 hp FI.
Mike
magius231
11-27-2003, 10:27 AM
I don't know about 450rwhp N/A car being more reliable than a 450RWHP FI car...the stresses put on the short block by the RPM needed to make those numbers far outweight the stresses placed on the motor due to forced induction...besides, if your reasonable with the boost and don't try to push the car to the edge, FI can be very reliable (witness the 200,000 mile GN's out there running 12's and 11's...) If you try to squeeze every last HP out of it, then yes its going to require a lot more work to keep it alive.
Rice Eater 316
11-27-2003, 04:57 PM
Well I was looking at running about 5-7 PSI boost no more. I want this to be a street car that kicks serious but. I've seen companies (Vortech and Procharger) advertise around 400 or so rwhp with this set up and that would be more than sufficient I imagine since that would be like...470 or so at the flywheel???
Anyways sorry about the confusion.
Does anyone have any good experiences with Vortech or Procharger. How bout the SLP H/C package.
Thanks.
engineermike
11-27-2003, 10:59 PM
http://www.thunderracing.com/index.cfm?fuseaction=content&contentid=49
443 rwhp at 6,100 rpm with HC. Sure, it peaks higher than stock, but the stresses placed on the bottom end by raising the rev ceiling by 500 rpm are far less than the stresses due to the increased cylinder pressure of supercharging. We're not talking about a 7,500 rpm heads and cam package.
Another advantage of HC over FI is that HC doen't make the engine harder to work on. FI congests the engine bay even worse than it already is.
If you decide to go HC, be sure that whatever HC package you decide on has dyno-proven results.
Mike
magius231
11-29-2003, 08:58 AM
Mike
www.ststurbo.com
no it doesn't :)
And I still disagree with you about the stresses on the engine, based on years of experience with Buick GN's.
engineermike
11-29-2003, 11:01 AM
Don't get me wrong, I think that the STS Turbo is a good idea, but it has some inherent flaws. Even Rick himself will tell you that if the exhaust system is cold, the turbo will not build boost. There simply isn't enough energy in the exhaust gas until you bring the whole exhaust system up to temperature. To me, this is a serious compromise since I try to cool my engine off as much as possible while at the track.
And about the Turbo Buicks, I was hoping I wouldn't have to point out the obvious here, but you are forcing me to. The 3.8 turbo was fully engineered to be a forced induction motor. It has a stout 6 bolt main iron block, low compression, and pistons with steel inserts to act as heat sinks to keep the aluminum cooler. You think the LS1's have these features? Don't think so.
My Ford Lightning will probably last 150,000 miles also. But guess what? It has a 6 bolt iron block, forged pistons, low compression, 42lb/hr injectors, twin fuel pumps, etc. . .
Are you trying to say that forced induction doesn't place any additional stress on the bottom end? You need to re-think that.
Mike
SageofKnight
11-29-2003, 12:07 PM
The TBs don't have 6 bolt mains...It's a simple 2-bolt iron block just like the N/A 3.8 of the time. Even the racing "stage" motors are only 4-bolts.
Based upon results I agree about getting HC for an LS1 car.
engineermike
11-29-2003, 01:47 PM
My bad. The block is an iron "skirted" style block, though.
magius231
11-29-2003, 02:51 PM
Mike
I think you need to revisit some of your turbo buick information...this is not correct. As you can see by this page
http://www.gnttype.org/techarea/pictureguides/blocks/blockguide.html
the N/A blocks and the turbo blocks are the same for 3.8 motors, even the metalurgy. The turbo 3.8 pistons were cast type pistons, not even forged...they are definitely better than the LT1 or LS1 pistons, but still not what a good aftermarket forged piston will be. Turbo Buick motors operate at around 8.5:1 compression, which is much better than an LS1 for boost, but they run almost 15psi stock which we aren't going to get close to without some bottom end work on these motors. Yes, forced induction does place stress on the motor, just as ANY HP increase will do, but it places less stress on the motor than more RPM does. I stand by that statement until someone can prove otherwise.
D James
11-29-2003, 05:49 PM
I say go forced induction, because over time you'll want more power, and I feel adding a charger is easier to do than pull the heads and throw in a new cam. Big cams tend to make driving pretty crappy, although that cam/head package at thunder racing looks pretty sweet. As far as the STS turbo that thing is pretty cheap, but having a turbo hang where someone can steal it really sucks, plus if your like me with longtube headers, you might not want to sell them and go back to stock. I am also wondering how low that thing hangs, cause I go over many speedbumps and steep driveways, I'd hate to scrape on that thing.
magius231
11-29-2003, 11:14 PM
the stealing the turbo thing is definitely a concern, I would fab some way to lock it in place. As far as it hanging down, it looks like its actually above the rear end, pretty much in the same spot as the muffler, and I've never scraped that so I'm not too worried. I know Rick was also working on getting an intake tube put together for guys with headers (LT's being the first to come out) so that may not be an issue either anymore.
93formula
11-30-2003, 02:50 AM
it doesnt hang much lower then the muffler, as for stealing, someone suggested tack welding the bolts, then when you go to remove them you can take a die grinder to remove them.
PNYKILR
12-02-2003, 04:38 PM
Mike
What he said-----------------Cartek, they are producing some awsome dyno/track times.
mnorwood
12-02-2003, 08:33 PM
If two engines make the same amount of power and torque with the same redline, why does the bottom end care if it's boosted or not? Torque (and thus power at a given rpm) is created by MEP; whether the engine is boosted, or just breathes well, won't change that.
I'm not talking about the ability to not detonate; rather, the ability to endure the forces in a non-detonating engine.
Is there something i'm missing?
93formula
12-02-2003, 08:53 PM
im guessing a FI motor is more likely to detonate. and im sure theres more to do with increased PSI as well.
neil350
12-02-2003, 09:09 PM
You gotta ask your self, do you want to rebuild that motor at some point in time? Judging by what you want, do a heads and cam set up, put in like a Walbro 340 fuel pump and spray a lil shot of gas on top.
engineermike
12-02-2003, 10:04 PM
If two engines of the same size make the same torque and horsepower at the same rpm, then you're right: there isn't a difference.
However, a supercharged motor will tend to make more torque (BMEP) in the midrange, which contributes to increased ring and bore wear as well as detonation.
A HC motor will make less torque than a supercharged motor, but will maintain it to a higher rpm to make about the same peak hp. So, a HC motor will have less ring and bore wear and detonation will be far less likely. A supercharged motor, however, will make it's hp at a lower rpm, thus reducing inertial stresses on the crank, rods, and bearings, but increasing stresses due to high cylinder pressure such as rod compression, main bolt tension, main cap bending, etc. . .
So, in normal operation, bottom-end stresses may be a wash, but would take some finite element analysis to know for sure. The detonation issue, though, is a real one. Once detonation begins, all bets are off on the bottom end, pistons, and rings.
Two weeks ago, I ran my supercharged car for 4 full-throttle pulls and registered less than 2 degrees knock retard. In other words, the tune was safe. Last Saturday night, I broke a piston due to detonation and still can't figure out exactly why.
Not to mention, it is a total pain in the @ss to work on a supercharged motor.
Mike
TimbrSS
12-02-2003, 11:16 PM
I think I'd wait till I actually had the thing for a couple months before I started to recommend it to anyone.
