OrionSPL
11-23-2003, 02:05 PM
I am in the process of putting my motor back in and bolting on my ATI Pro-Charger D1-SC. Anyone know what gap I should use with the NGK TR6s? I will be running 12lbs of boost on the street with 94 and 14lbs at the track with 110. I also have an MSD 6AL, other mods listed in profile. Thanks!
My ambitionz
11-23-2003, 04:33 PM
hey orion, I'll be running a very similar setup to you: ls6 stage two heads, and a d1SC as well. I got a ten pound pulley to run on it. My question to you is. Are you gonna run 14 psi with stock CR/bottom end?
My ambitionz
11-23-2003, 04:35 PM
EDIT: just read your sig... Never mind. Although what CR are you running?
OrionSPL
11-23-2003, 06:33 PM
I am running 9.1:1 compression ratio.
IDOXLR8
11-23-2003, 10:03 PM
I usually recommend gapping them at .032
