TEXASZ
11-23-2003, 11:28 AM
After more than ten 10 second passes, the 10 bolt finally gave up. Not bad for running 4.10's in a stock rear. We are going to a Strange 12 bolt with 4.10's and a full spool. Anyone have an idea how much the extra weight will slow us down? Hopefully not several tenths. Ha Ha.
Stephen 87 IROC
11-23-2003, 11:45 AM
http://www.chevyhiperformance.com/techarticles/0304_nine/
I cant believe it lasted that long!
Camaro_Guru16NY
11-25-2003, 11:57 AM
He He 10 bolt goes BOOM funny. Sorry about your luck man i dont think a 12 bolt takes off that much time but probably some if you dont have the HP and TQ to make up for it...
Later,
-John
JWINN
11-25-2003, 12:57 PM
Hey John,
You have a car that is running as fast as yours is why not go with a Mark Williams Ford 9"? These rear ends are much lighter then the 12 bolt and IMO stronger. You can actually have a chromoly 9" housing made for super weight savings.
I run a custome chromoloy 9" housing with Stranging Engineering Ultra case senter section with a titanium spool and pinion yoke with the big 9.5 ring and pinion. This will never break and is way lighter than the 12 bolt.
"White Knight"
11-30-2003, 10:25 PM
No Ford for me:D
Just ain't right....IMO
scott9050
12-01-2003, 02:47 AM
Since the 12 bolt is similar in strength to a Ford 8.8, yeah, the 9 inch Ford is stronger.
