chamorro
11-22-2003, 09:25 PM
has anyone tried it? im thinking of getting it, but i dont know if it actually works, or its just a haox. but it says motor trend approved of it. so has anyone ever tried it?
Does that Mr. Clean Autro Dry car cleaner really work?chamorro 11-22-2003, 09:25 PM has anyone tried it? im thinking of getting it, but i dont know if it actually works, or its just a haox. but it says motor trend approved of it. so has anyone ever tried it? 99huggerorangeZ 11-23-2003, 02:19 AM i saw that to and would also like to know more about it Camaroman_94 11-23-2003, 05:31 AM Ditto.. DARK AGE 53 11-23-2003, 09:04 AM I haven't tried it but doesn't it have a money back guarentee, I might try it on my daily driver but I doubt I'd use it on my Camaro. JMO Al 1dreamz 11-23-2003, 09:19 AM I'm not sure if it works or not but the idea does. I work in the water purification field and the spotless car washes use an method known as ion exchange. The way it works is water passes through charged resin beads which attract the impurities in the water. If you have no impurities in the water the water will dry without spots, as water spots are the minerals etc left behind after the water dries. My gut instinct tells me this probably wouldn't work perfectly or for too many washes. From what i have seen it is fairly small and I'm wondering how they recharge the resin?? Rogue Leader 11-23-2003, 11:07 AM Originally posted by 1dreamz I'm not sure if it works or not but the idea does. I work in the water purification field and the spotless car washes use an method known as ion exchange. The way it works is water passes through charged resin beads which attract the impurities in the water. If you have no impurities in the water the water will dry without spots, as water spots are the minerals etc left behind after the water dries. My gut instinct tells me this probably wouldn't work perfectly or for too many washes. From what i have seen it is fairly small and I'm wondering how they recharge the resin?? It has cartriges you buy and replace in it every few washes or something... rncotton 11-23-2003, 11:13 AM Someone get them to send me a free setup, and I'll gladly try it out on my black WS6 and post the results. :D | ||
