GT40MkI
11-22-2003, 01:26 PM
got my vortech kit on, I was seeing 4 psi but when it hit 5+ it would go to zero, now I am seeing 1psi max mostly zero
help :(
help :(
makeing no boostGT40MkI 11-22-2003, 01:26 PM got my vortech kit on, I was seeing 4 psi but when it hit 5+ it would go to zero, now I am seeing 1psi max mostly zero help :( GT40MkI 11-22-2003, 01:27 PM also my fmu is not spikeing, I have tried 2 fmus and even a super fmu IDOXLR8 11-22-2003, 05:41 PM It sounds to me like you are having belt slippage. If the belt is not slipping then you may have a vaccum leak. GT40MkI 11-23-2003, 07:16 PM Originally posted by IDOXLR8 It sounds to me like you are having belt slippage. If the belt is not slipping then you may have a vaccum leak. well no belt slippage i think i may have a vacuum hose wrong maybe the ones for the opti, i just left them how the were. does anyone have pictures of the top portion SMOKNZ 11-23-2003, 07:40 PM Ummmm, A 1/8th inch tube isn't going to bleed all the boost from a blower... Bill JordonMusser 11-23-2003, 10:25 PM sounds like you are possibly collapsing the intake tube, or the belt is slipping. boosted-lt1 11-23-2003, 10:39 PM If you see NO BOOST on the gauge at all now, maybe check the line from intake to gauge. I had a tear in mine and at a certain point it showed I wasnt making anything. The way I understand , You are ssing NO positive pressure on the gauge at all . -Scott engineermike 11-23-2003, 10:52 PM The bypass valve could be stuck open. Seriously, you should run the Opti vent lines how Vortech recommends. You are pressurizing you Optispark, which I'm sure it wasn't designed for. Mike | ||
