Teal96TA
11-20-2003, 09:32 PM
How can you tell from a dyno graph what the best shift point would be for your car?
Best Shift Point?Teal96TA 11-20-2003, 09:32 PM How can you tell from a dyno graph what the best shift point would be for your car? rskrause 11-21-2003, 05:17 AM It's easier to show it grahically than to explain it. You want maximum area under the torque curve. By superimposing the torque curves in each gear, shift points can be easily estimated visually. Look at http://wahiduddin.net/race/dynotest.htm to see what I mean. Rich Krause Teal96TA 11-21-2003, 07:06 PM Ok, I'm with you so far I think, but you don't want to do it too soon or you end up too low in the RPM's right? Which means you have to go past the peak x amount. How do you determine the value of x? rskrause 11-21-2003, 09:51 PM Originally posted by Teal96TA Ok, I'm with you so far I think, but you don't want to do it too soon or you end up too low in the RPM's right? Which means you have to go past the peak x amount. How do you determine the value of x? One method is to make a graph like the one in the link. Then you simply shift at the rpm represented by where the lines cross. Rich Krause | ||
