fuel line problems (fittings)
00LukeyWS6
11-20-2003, 08:55 PM
i moved a 98 LS1 motor into a 77 K20 with the fuel pump, the original fuel lines (after re-bending) are too short, so i need to extend or re-do.
what i want to do is to go from the stock LS1 fittings to AN fittings, that would make my life so much easyer, the problem is i don't even know what the stock fittings are called, and ive been having a hella time trying to get this to work, any suggestions? better way to do it? adapters? (i want to keep the number of connections to a minimum)
Lukeys bro
dave1w41
11-20-2003, 09:22 PM
There are adapters for this. You need to get on the phone to Earls or Aeroquip.
00LukeyWS6
11-20-2003, 09:33 PM
called earles today, they said they don't have anything,
have anymore info on the other place? web site? ph #?
Kwiksilverz28
11-20-2003, 09:46 PM
Cut the lines and flare the after putting whatever fittings on that you want. It is not that hard....
00LukeyWS6
11-20-2003, 10:05 PM
yah, i thought about that, but like i said, i want to keep the number of connections to a minimum, if i can't come up with anything else by saturday ill do that.
