Best way to Launch A4
rome856
11-20-2003, 07:14 PM
I have a 96 Z28 A4 pretty much stock except for a cat back and ram air hood. I have been running consistent 2.0 60' times by starting w/ one foot on the brake and then moshing the gas on the light.
Does power braking give a better launch? I have a stock converter, factory 3.23 gears, and goodyear eagles.
Fred94LT1
11-20-2003, 09:20 PM
2.0 on that setup isn't bad. I would suggest trying to launch the same way but side stepping the brake when you wanted to launch, when brake standing it to 1200 rpm's. If you hook the 60' should drop to 1.9x, and you might even trap a little higher, Fred
FacelessZ
11-20-2003, 11:14 PM
don't know what to tell you for NOW, but a line lock is always a lot of fun...:eek:
that and at least a 2800 stall....
Tekprodave
11-21-2003, 06:57 PM
I get my best results launching with just a bit of gas to get the RPMs to about 1200 or so. Mine ran mid 14's with your configuration.
