South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Anyone have a set of LS1 axles?
Old Nov 19, 2003 | 08:50 PM
Soma07's Avatar
Like the subject says i'm looking for a set of LS1 axles (cheap). I just need the axles themselves, not the housing or anything. Also they MUST be out of an LS1 or 98+ V6 car that didn't have traction control (i.e. no ABS reluctor rings).
Thanks!
Old Nov 20, 2003 | 01:03 AM
YOSHI`S Z28's Avatar
hey jason,
now what would you possibly need those for?
i know your a smart guy but,,you have an lt1.lol
fill me in if you know something i dont, i need new axles on my car.
josh
Old Nov 20, 2003 | 04:08 PM
Soma07's Avatar
The LS1 axles are about 1/4" shorter than their LT1 counterparts. I need them because I am now running LS1 rear brakes on my LT1 rearend and without the shorter axles the rotor isn't quite centered in the brake pad bracket like it should be. I've used some shims (washers) to get everything to line up but I would rather do it "right" since brakes are kind of important
Also the "hat" on LS1 rotors is also hair thicker (~1/16") so I suspect the LS1 axles will have longer wheel studs to compensate. As it sits now with the LS1 rear brakes and LT1 axles the lugnuts don't engage the stud quite as much as they used to. Its probably fine but since I need the axles anyways...
BTW if I get a set of LS1 axles you're welcome to my LT1 axles. I'll trade you a six pack or something for them. I'll have three (well four actually, but one is bent).
Old Nov 21, 2003 | 02:42 AM
hey jason,
that would be great
im sure we could figure something out for your stock ones,
please let me know if you find some ls1s ,you dont know how much that would mean to a broke student.
tthanks,
josh
Old Dec 2, 2003 | 01:32 AM
Soma07's Avatar
Josh,
Check your PM box
ddr698
Jan 9, 2015 10:05 AM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
