Battery volts drop to 8
jer4251
11-19-2003, 09:32 PM
not sure what the problem is but from time to time the battery gage will drop almost all the way to 8. the car is a stock 99 V6 with 20k miles on it, the alt was just replaced less than a month ago. the lights all flicker and dim and then it goes back to 12/13 volts and goes normal.
has anyone had this problem before? if i turn the steering wheel all the way to a side i can hear a funny noise and the batt volts drop, they drop more often right after acceletation.
thanks
atl2001
11-20-2003, 03:31 AM
why was the alternator replaced? often times if the alternator dies it hits the battery pretty hard when it dies, it may have caused the battery to not accept a charge as well as it should, thus making the battery fail now.. take it to an autozone and have it tested
96 camaro 4 life
11-20-2003, 03:29 PM
I had my alt replace a while ago and soon after my battery went. It wouldn't hold a charge which meant a few jumpstarts. Now i've got a new batt and its fine.
Javelin3o4
11-20-2003, 08:45 PM
Check your grounds cable, also check the engine to body ground and also some have a cable that runs from the neg bat cable to the body aswell.
