SES Light....
Rogue Leader
11-19-2003, 07:01 PM
Im new to LS1's and OBD2 cars, I got an SES light on the parkway today it hard coded because it wont shutoff at all, so I know its a definite problem.
Firstly, can you check codes on this car by jumping out the ALDL like on older OBD1 cars??
Secondly, does anyone have a listing of codes??
And third, the small barrel connector on the passenger side between the battery and the ECM, is that the power wire for it to reset it (It usually is, just checking...)???
Thanks!
Schantin
11-19-2003, 07:11 PM
Thanks!
To answer your Q's.
1. No. The OBDII system can't be read via "paperclip" like the older OBDI can.
2. Any AutoZone store will read your OBDII code for you free of charge. They will not reset the code, however....just read it. You can also buy a OBDII reader for $149 from them. Their reader will ID the code. Otherwise a Haynes manual lists the PCM malfunction codes as well.
3. By disconnecting the negative battery cable for 5 seconds and then reconnecting it you will "reset" the code. The code will still be in the PCM memory, but the SES light will go out. A 8mm socet or wrench will disconnect the negative battery lead.
Hope this helps :)
Schantin
2002 Camaro Z28 M6 :usa:
Camaro_Guru16NY
11-21-2003, 11:50 AM
As far as I know the SES light only deals with emissions only. So it could be something like a bad 02 sensor. I dont think it would be anything major. My buddies light came on after installling a cut out.
Good Luck,
-JOhn
2001NBMZ28
11-21-2003, 12:33 PM
DTCs can be several things, especially if you have an A4. Have the code(s) read. For a list of possibilities see www.ls1.com/DTClist.htm
demonspeed
11-21-2003, 05:38 PM
Good Luck,
-JOhn
Mine is on due to a knock sensor... I just use my Diablo to reset it every once and a while.
By the way... I say don't waste your money on a scanner that only scans. Spend the extra money on the Predator because you can scan and erase and tune your car.
Rogue Leader
11-21-2003, 07:07 PM
I agree... I plan on getting a predator so I dont wanna waste my cash on a scan tool.
Looks like a buddy may have one so I might be in luck!
Rogue Leader
11-23-2003, 11:04 AM
P1415 AIR System Bank 2
I checked the AIR tubes on the passenger cylinder bank and didnt see or hear any leaks and all the seals are in place.. the drivers side looked fine too...
I re set the light and took the car around the town few times with the OTC in data logging and didnt see anything bad, the AIR system was functioning normally ccording to the OTC...
Any ideas... I was thinking maybe I had some stale gas or something...
rncotton
11-23-2003, 11:17 AM
CIRCUIT DESCRIPTION
The air pump used on this vehicle lower tail pipe emissions during start-up. The AIR system consists of the following items:
The air pumps
The check valves
The vacuum solenoid
The system hoses and pipes
The AIR relays, fuses, and related wiring
The PCM uses the AIR relays to control the air pumps. The PCM also controls the AIR vacuum solenoid that supplies vacuum to the AIR check valves. With the AIR system inactive, the AIR check valves prevent air flow in either direction. With the AIR system active, the PCM applies ground to one of the AIR relays, and the vacuum solenoid. Then the PCM applies ground to the other AIR relay. Fresh air flows from the pumps, through the system hoses, pass the check valves, and into the exhaust stream. The air helps the catalyst to quickly get to a working temperature; thus lowering the tail pipe emissions on a start-up.
The PCM tests the following AIR system components:
The overall AIR system, including both banks - any problems detected here will result in DTC P0410.
The AIR system bank 1 (DTC P1415)
AIR system bank2 (DTC P1416)
AIR relays (DTC P0418, and DTC P0419)
AIR vacuum control solenoid (DTC P412)
The PCM runs two tests to diagnose the AIR system:
Passive, and Active. Both tests involve a response from the fuel control H02 sensors (HO2S bank 1 sensor 1 and HO2S bank 2 sensor 2). The Passive test consists of two parts. If both passive tests pass, the PCM takes no further action. If either part of the passive test fails, or is inconclusive, the PCM initiates the Active tests. If the PCM determines that HO2S bank 1 sensor 1 did not respond as expected during the tests, DTC P1416 will set.
CONDITIONS FOR RUNNING THE DTC
Passive Tests:
The engine is running.
The engine speed is more than 600 RPM.
The throttle is steady
The engine load is less than 80 percent.
The system voltage is more than 10.5 volts.
The MAF is less than 35 g/s.
The air fuel ratio is more than 12.5:1
The ECT is between 0°C and 108°C (32°F and 226°F) .
The IAT is between 0°C and 60°C (32°F and 140°F ).
The power enrichment, or deceleration fuel cut-off is not active.
Active Tests:
The throttle is steady.
The fuel system is in close-loop operation.
The EVAP purge is active.
The ECT is above 68°C (154°F) .
CONDITIONS FOR SETTING THE DTC
Passive Tests:
During the operation of the air pumps, HO2S bank 1 sensor 1 voltage remains above 470 mV for 20 seconds (450 mV for 7 seconds on a hot start). OR
When the air pumps are turned OFF, HO2S bank 1 sensor 1 voltage remains below 700 mV for 25 seconds.
The PCM initiates the active test due to a failed or an indeterminate passive test.
Active Test:
A failed or an indeterminate passive test
The HO2S bank 1 sensor 1 voltage remains above 35 mV.
The PCM detects a failed passive test and two failed active tests. OR
The PCM records an indeterminate passive test and three active tests.
ACTION TAKEN WHEN THE DTC SETS
The PCM illuminates the Malfunction indicator lamp (MIL) during the second consecutive trip in which the diagnostic test runs and fails.
The PCM stores the conditions present when the DTC set as Freeze Frame and Fail Records data.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM will turn the MIL OFF after the third consecutive trip in which the diagnostic runs and passes.
The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool Clear DTC Information function.
rncotton
11-23-2003, 11:19 AM
Diagnostic Aids
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Are any of the following DTCs set?
DTC P0410
DTC P0412
DTC P0418
Go to applicable DTC table first
Go to Step 3
Check for a blown AIR pump bank 2 fuse.
Is the fuse blown?
Go to Step 12
Go to Step 4
With the scan tool installed, command the AIR pump bank 2 ON and OFF.
Does the AIR pump turn ON and OFF?
Go to Step 11
Go to Step 5
Is the AIR pump running continuously?
Go to Step 9
Go to Step 6
Remove the AIR relay.
Using the appropriate jumper connectors, jumper the battery positive feed and the AIR pump feed cavities in the relay connector.
Is the AIR pump running?
Go to Step 8
Go to Step 7
Check for the following circuit conditions:
An open battery positive feed circuit between the AIR fuse and the AIR relay.
An open AIR pump feed circuit
An open/poor AIR pump ground circuit
Faulty connections at the AIR pump
If the condition is found, repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 16
Check for poor terminal connections in the relay connector.
If the condition is found, repair as necessary. Refer to Connector Repairs or Wiring Repairs in Wiring Systems.
Go to Step 20
Go to Step 17
9
Go to Step 10
Go to Step 17
10
Locate and repair the short to voltage in the circuit between the AIR relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 20
11
A short to ground in the circuit between the AIR pump fuse and the AIR pump relay
A short to ground in the circuit between the AIR relay and the AIR pump
Important
Be sure the replace the AIR pump fuse.
Go to Step 20
Go to Step 16
12
Disconnect the AIR hose/pipe from the AIR shut-off valve.
Using the scan tool, turn ON the AIR pump.
Is air flow present?
Go to Step 13
Go to Step 15
13
Reconnect the AIR hose/pipe to the AIR shut-off valve.
Disconnect and plug the vacuum line between the AIR vacuum solenoid and the AIR shut-off valve.
Start and idle the engine.
Connect a vacuum pump and a piece of vacuum line to the AIR shut-off valve.
Apply 40.63 kPa (12 in Hg) to the AIR shut-off valve.
Observe the HO2S bank 2 sensor 1 voltage while commanding the AIR pump ON.
Is the HO2S bank 2 sensor 1 voltage below the specified value?
250 mV
Go to Step 18
Go to Step 14
14
Check the AIR hose or pipe between the shut-off valve and the exhaust manifold for the following conditions:
Any blockages or restrictions
A kinked, pinched, or damaged condition
A faulty connection at the AIR shut-off valve or the exhaust manifold
Go to Step 20
Go to Step 19
15
Check the AIR hose or pipe between the AIR pump and AIR shut-off valve for the following conditions:
Faulty or damaged connections at the AIR pump
Go to Step 20
Go to Step 16
16
Replace the AIR pump. Refer to AIR Pump Replacement bank 2.
Go to Step 20
17
Replace the AIR relay.
Go to Step 20
18
Replace the vacuum line between the AIR vacuum solenoid and the AIR shut-off valve.
Go to Step 20
19
Replace the AIR shut-off valve.
Go to Step 20
20
Review and record the scan tool Fail Records information.
Clear the DTCs. Operate the vehicle within the Fail Records conditions.
Monitor the scan tool Specific DTC Information for DTC P1416 until the test runs.
Does the scan tool indicate that DTC P1416 passed?
System OK
Rogue Leader
11-23-2003, 01:42 PM
WOW thanks!!
if it throws the code again im gonna go through that....
I appreciate it!!!
