Best drag radial tire size?
MTL_Z28
11-19-2003, 02:02 AM
I was thinking of purchasing a set of drag radial tires (either Nitto's or BFG's) for the track and was wondering what size would give me the most traction (I want to lower my 60' s as much as I can)?
I could mount them on 16" x 8" salad shooters and have 245/50 which would give me more sidewall and the rims would be lighter. on the other hand, I could mount them on 17" x 9.5" rims that I have and I would get a bigger patch for increased traction however the rim would weigh more and less sidewall also and they would be more expensive.
Which are better?
Is there a good combination that someone can recommend?
MBonZ28
11-19-2003, 02:25 AM
is the car an auto or stick....how much power does it make?
will these be for track use only?
GREGG 97Z
11-19-2003, 04:40 PM
If they are just for the track use get some 255/50/16 BFG drs. I have them on salad shooters for the track and I also have 275/40/17 Nitto dr's on ZR1's for the street. I've run with both at the track and the BFG's hook up better than the larger Nittos. You want a taller sidewall for more flex for drag racing. I got wheel hop sometimes with the 275 Nitto's, I never get any hop with the 255 BFG's plus they are lighter. Also I run them with 17-18lbs of pressure.
Javier97Z28
11-19-2003, 05:00 PM
You can't lose with either, the Nitto's will last a little longer than the BFG's but you may give up a bit of traction for them. Either way, go for the 16" tire.
I've had good luck with the Nitto's, cut 1.7x's consistently.
94ZRiCeKiLr
11-19-2003, 06:18 PM
just to add my own opinion.....i dont know why anyone has a problem with 17 inch Nittos....my car doesnt make a whole lot of power but IT HOOKS on the 17s without any wheelhop at all..ive gone 1.6X 60 foot a bunch of times on those tires...
MTL_Z28
11-20-2003, 01:25 AM
Just to add more info...
My car is pretty much stock for now, 6-speed tranny and stock 3.42 gearing. However next year I will be adding some bolt ons (might go to 4.10's).
Either way it looks like I will be going for the 255/50/R 16 size tires mounted on salad shooters.
Thanks for the advice!
