what rear end gears do I have?
Old Nov 18, 2003 | 04:57 PM
OutlawLS!'s Avatar
How can I find out what rear end gears I have?
I'm believe I have 2.73's since I have an A4, but am not sure.
The drivers side door does not have the label on it with the codes. ( Previous owner had someone back up into the door, so he completely switched it out.)
Any other way I can find out?
Old Nov 18, 2003 | 05:19 PM
SSpdDmon's Avatar
Next time you go for a drive, check where your RPMs are at a given speed. Then go to http://www.f-body.org/gears/ and plug in your tranny with the chart. It'll tell you what RPMs you'll be at for a given speed.
Example -
A4 with 3.23's = 31 MPH @ 4,000 RPM in 1st gear
A4 with 2.73's = 37 MPH @ 4,000 RPM in 1st gear
Hope this helps...
Old Nov 18, 2003 | 06:58 PM
Capn Pete's Avatar
OR..........cruising at 70 - 75 mph (in overdrive) is around ~2000 RPM!
As well, I "think" that 3.23 cars have an aluminum driveshaft, whereas 2.73 cars have a steel driveshaft (although I think I've heard stories of opposite scenarios..........but those have probably been either factory screw-ups, or maybe cars switched from one to another before change of ownership, then the new owner says "...but I've got an aluminum DS with 2.73's??" .
Old Nov 18, 2003 | 09:03 PM
Chrisz24's Avatar
I once hurd something like a 2:73 car wont allow you to shift into 1st where as a 3:23 car will.
Old Nov 18, 2003 | 10:03 PM
OutlawLS!'s Avatar
I think that has to do with some sound or emission issues. I haven't heard that realated to gears.
Thanks alot guys.
Old Nov 18, 2003 | 10:30 PM
Capn Pete's Avatar
That's with LT1 F-bodies................with LS1 F-bodies, you can shift into 1st regardless of 2.73 or 3.23.
Old Nov 22, 2003 | 10:08 PM
Rice Eater 316's Avatar
Question
Hey I think that helps me as well. I have 2002 Z28 M6 that I bought used about 2 weeks ago with 8900 miles. The previous owner did some mods and I've figured out a coupla of them but didn't think about the rear end. I turn about 1900-2000 rpm in 6th gear @ 70 MPH According to that chart I figured about 4.11 gears... does that sound right?? Also is that desirable or not??
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
