What does this ET translate to with a 2.0 60'
danno02SS
11-18-2003, 03:25 AM
Anyone know approximately what this ET will drop to with a 2.0 60 foot?
R/T 0.825
60' 2.315
330' 5.917
1/8 ET 8.828
1/8 MPH 85.29
1/4 ET 13.474
1/4 MPH 105.84
Is there more MPH to be had with a better 60 foot? Thanks.
HungryT/A
11-18-2003, 04:45 AM
I have made some calculations for you:
With a 2.0 60' ft, on a 12" rollout tree, you would have the following times:
330' 5.538
1/8 ET 8.450
1/8 MPH 86.07
1/4 ET 13.008 <-- :eek: :D
1/4 MPH 106.36
So, you see, you gain a lot in ET by improving your 60'ft., but you will run basically the same 1/4 MPH
Speed Inc.
11-18-2003, 12:03 PM
330' 5.538
1/8 ET 8.450
1/8 MPH 86.07
1/4 MPH 106.36
SOUNDS ABOUT RIGHT
I usually see 2 tenths up top from ever tenth improved in the 60ft.
Larry
danno02SS
11-19-2003, 01:13 AM
Thanks Guys!
Damn my car is slow! Those times are after the CAM install. I was running a 13.834@102 with a similar 2.305 60'. Kinda makes me regret opting for the leather interior now.
AL SS590 M6
11-19-2003, 02:49 AM
Originally posted by danno02SS
Thanks Guys!
Yes, but what elevation are you running at? Elevation and weather can make huge differences in 1/4 times and mph.
HungryT/A
11-19-2003, 04:36 AM
Thanks Guys!
This is after the cam install?! Hmm...Have you had your PCM reprogrammed? I run 13.48 all day with a good tune and an otherwise mild bolt on LT1, on motor. Considering, that you have a cammed LS1, your mph seems waaay low for me, but correct me please if I'm wrong!
For a good PCM tune drop a line to Madwolf, he can set you up.
DB75
11-19-2003, 11:56 AM
For every tenth you knock off on your 60 ft. equates to 2 tenths in the 1/4. Somebody correct me if I'm wrong.
danno02SS
11-21-2003, 03:18 AM
OK somebody tell me what is wrong with my car.
Here are two runs one stock (full weight, 1/2 tank), one with LID/K&N/LS6 cam &springs/!spare/!jack (1/2 tank). Both at carlsbad CA, 120 ft above sea level, in 77-85deg. weather.
________stock______modded
60'______2.306_____2.315
330'_____6.035_____5.917
1/8 ET___9.063______8.828
1/8 MPH__81.84_____85.29
1/4 ET___13.875_____13.474
1/4 MPH__102.00_____105.84
Why is my MPH so low
:cry:
danno02SS
11-21-2003, 03:48 AM
I'm still running the factory LS1 tune. I wasn't planning on getting it tunned till after the shorties, and cutout. I know I at least need to up the rev-limiter to 6600 and the shift points to 6300-6500 to see better gains with this cam. The car dynoed 306.9rwhp/325.8rwtq bone stock and 309.6rwhp/328.7rwtq with the lid and filter. Those numbers should be good for a 104-105 trap right?
HungryT/A
11-21-2003, 04:19 AM
Who did the cam swap? Are you sure it was done right?
You can get a tune now, and as add more parts to your car, you can have it tunde for the upgrades free.
Rival
11-25-2003, 01:07 AM
You mph is so low because of the 60ft times. You pick up a solid .4 from the mods? That isn't too good for a lid and ls6 cam. Buy some drag radials, lca's and subframes connectors. It will really help you out.
