93Cam
11-17-2003, 08:58 PM
Recently i've been looking a lot at cams because my stcok 3.4 just isn't doing it for me. So, my question is, would the lunati 228/228 cam be too aggresive for my daily driven beast, or should i go for a more mild cam. If so, what would you guys recomend. Thanks for any input.
Steve
kmook
11-17-2003, 10:27 PM
Hey Steve,
I dont have any personal input on a cam for you as i've never really done much on the v6 side...
But general cam discussion/recomendations should be discussed in a generation spacific forum. Transfering- Thanks.
atl2001
11-17-2003, 11:21 PM
is that dur , or adv dur?
oil pan 4
11-18-2003, 03:16 AM
how much lift does it make?
93Cam
11-18-2003, 12:29 PM
duration is 228/228 at .050, lift is .465 with 1.5 rockers, lobe seperation angle is 110, and intake centerline is 106. It is a hydraulic flat tappet cam.
93Cam
11-19-2003, 09:53 PM
30 views and two people talk. :rolleyes:
oil pan 4
11-20-2003, 07:14 AM
That is to much lift for stock springs You will need some new springs.
For $42 YOu can get Kmotion K-700 valve springs from summit and fhose are good for .5'' of lift.
atl2001
11-20-2003, 11:52 AM
it wont be the best on the street, any aftermarket cam will be worse on the street over the stock one, but it should be driveable still, but yes it should be rough
93Cam
11-21-2003, 10:47 PM
thanks a bunch guys, so what is a good cam that wouldnt be outrageously rough or bad on gas?
oil pan 4
11-22-2003, 04:43 AM
crane cams 2-272-H
216*/228*
.454''/.480'' with 1.5 rockers or .480''/.511'' with 1.6's
