irocz383
11-17-2003, 02:03 PM
I built a 383 stroker with AFR 190 Heads and a custom cam. The cam is ...
at .050 duration 230 intake 242 exhaust
Gross vavle lift is .510 intake .540 exhaust
LSA 113
I've had numerous tunes on the chip and its finally starting to run better but now I have a sputter. It only sputters between 3000 and 4500 RPM. Before and after those RPM's it climbs no problem. Could this be a timing issue? Everything is new accept for the MSD 6AL box and coil. I was going to change the plugs again to see if they were misfiring. A budy of mine suggested moisture in the cap. I haven't had the chance to look into that.
Any suggestions would be great!!
Thanks in advance!
-Ken
LSA 113
Thanks in advance!
-Ken
