high idle...
Javelin3o4
11-17-2003, 12:54 AM
is there a way to adjust the idle? mine starts at like 2K and works down to about 1.5K sometimes.
camaro6
11-17-2003, 01:23 AM
I've got the same problem. I haven't had time to try and fix it yet, but here are the responces i got in another thread.
here (http://web.camaross.com/forums/showthread.php?s=&threadid=189634)
edit: I just saw you emailed me about it:p
MustangEater82
11-17-2003, 12:59 PM
I am assuming its a 3.4L?
IF so I woudl check the vacuum T connector about 8 in. behind the TB, look at it closely, mine got a hairline crack, and an intake laeak causing high idle.
Javelin3o4
11-17-2003, 10:49 PM
its the 3.1 Multi-Port Fi..v6 '90 firebird. Ive replaced the TPS, Ignition Module, Plugs, Cap, Rotor.
