LSs1Power
11-16-2003, 09:55 PM
I was trying to get my best after the cam and latest dyno numbers........ When i first came to the track i did a run without changing anything such as tire pressure or taking the tools out of my car and ran 12.6 at 108 with a 2.0 60ft spinning all the way.... The 108 is because i didnt shift to 4th thinking i would get through the traps before i hit the rev limiter, but i was wrong. Still a new best without shifting to 4th is nice :) .
After that i went back to the pits and took everything out of the car and lower the Tire pressure to 20psi.... I did a 7 sec burn out hoping to get 1.760ft or so..... I launched at 5500RPM the face of the car just lifted(Perfect launch) and after that i hear this BOOOOM Clig Clig Clig Clig....... Check out the pic and u wont believe what GM has in our stock parts:
Look at this http://www.msnusers.com/CarsRelatedGroup/shoebox.msnw?action=ShowPhoto&PhotoID=11
And this
http://www.msnusers.com/CarsRelatedGroup/shoebox.msnw?action=ShowPhoto&PhotoID=12
And this
http://www.msnusers.com/CarsRelatedGroup/shoebox.msnw?action=ShowPhoto&PhotoID=13
This is a close up
http://www.msnusers.com/CarsRelatedGroup/shoebox.msnw?action=ShowPhoto&PhotoID=14
The last one
http://www.msnusers.com/CarsRelatedGroup/shoebox.msnw?action=ShowPhoto&PhotoID=15
CARD BOARD inside our stock Drive shaft......... Do u guys believe this? :confused:
All the time i was worried more about my rear end, but never thought my drive shaft was in danger too. Anyways thank god its the drive shaft and not the rear end. Advice to all the guys pushing alot of HP, change ur drive shaft before it snaps.
And this
And this
This is a close up
The last one
