Newonad
11-16-2003, 07:47 PM
I know that this type of thing gets old after a while, BUT would someone PLEASE simulate this combo and post the results using these 2 cams . Courious to see what it's SUPPOSED to do. want to reach 500 tq/hp na. Thank you so much. Dan
1. CC XS274S(12-677-4) 236/242@.50 .501/.510 lift
2 .CC XS282S(12-678-4) 244/252@.50 .520/.540 lift
383 stroker with forged flat-tops (10.3:1 cr)
Steel crank/rods
AFR 210 Heads as cast w/ 2.08/1.6
1.6 Roller tip rocker arms
750 cfm Speed demon mech seconds w/RPM air gap intake
Stock HEI w/pertronix kit
8 mm plug wires
1 3/4 headers and 3" collectors
windage tray
7 qt baffled oil pan
will spray 100-300 hp
Donor Vehicle(as in GIVEN to me):
1985 IROC Z-28 w/o engine or trans(will build-up a PERFORMANCE 200r4)
Converter will be based on engine output(2-4k stall)
3.73 rear axle ratio
Approx weight b-4 dieting 3500#
Hot street/Bracket racing
NOT a daily driver but a weekend bruiser
Steel crank/rods
8 mm plug wires
windage tray
