Janny
11-11-2003, 04:02 PM
Like it says, I want to buy a T56 swap kit. Anyone in the Michigan, Sw Ontario area got one?
WTB T56 Swap kitJanny 11-11-2003, 04:02 PM Like it says, I want to buy a T56 swap kit. Anyone in the Michigan, Sw Ontario area got one? redroc wrench 11-11-2003, 09:00 PM I have the tranny if you need it. It came out of a 96 Firebird with about 8,000 miles on it. It broke the 5-6 synchronizer and gears. Now has new 5-6 synchro, 5th and 6th gear, new countershaft and D&D steel 3-4 fork. I am just putting it together now. I am a GM dealer tech in Okemos. I know you will still need a lot more parts but this could be your start. I am thinking it may be worth around $1200? Let me know if this sounds like it would work for you. Call me at (517)294-1879. Andy 91 Redd Sledd 11-11-2003, 09:13 PM cool another number for the rest area walls......... dreamer1q 11-11-2003, 10:03 PM I can probably get you the pedals you will need, and maybe a console if you need it. With Redroc's tranny, your all set other then a clutch setup and master cylindar. I might be able to kick up a crossmember too if your lucky. Q Grover 11-11-2003, 10:12 PM Q, do you have any M6 consoles out of 97+ Pontiacs. I broke the little spring mounting tab for the ash tray cover on mine when I put the switches in there. All I really need is the top half. dreamer1q 11-12-2003, 06:33 AM Originally posted by Grover Q, do you have any M6 consoles out of 97+ Pontiacs. I broke the little spring mounting tab for the ash tray cover on mine when I put the switches in there. All I really need is the top half. They are all broken like that. The one Dave bought from me, and the one in my car are broken too. I think it is a factory requirement. Q Janny 11-12-2003, 03:17 PM Will call, shortly. Janny 11-12-2003, 03:45 PM Hey Dreamer, if you can get that pedal assy. and crossmember let me know. It looks as if I'll be needing one. dreamer1q 11-12-2003, 04:49 PM Originally posted by Janny Hey Dreamer, if you can get that pedal assy. and crossmember let me know. It looks as if I'll be needing one. Will do, I am pretty sure I have the pedals already. Will start looking for the crossmember tonight. Q Janny 11-12-2003, 05:00 PM Fabulous! I'm getting pretty psyched about doing the t56 swap now! Yippeee! :D Janny 11-14-2003, 05:24 PM Originally posted by dreamer1q Will do, I am pretty sure I have the pedals already. Will start looking for the crossmember tonight. Q Hey Dreamer did you find any of these things? dreamer1q 11-14-2003, 06:09 PM Yeah, I found the pedals. No luck on the crossmemeber. Figure 50 bucks on the pedals and I will ship them to ya. Q Janny 11-14-2003, 10:36 PM Originally posted by dreamer1q Yeah, I found the pedals. No luck on the crossmemeber. Figure 50 bucks on the pedals and I will ship them to ya. Q I can live with that as long as they have the electrical connections in place. | ||
