South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
88 Monte SS SBC383/th400 F/S or trade.
Old Nov 6, 2003 | 08:24 PM
ANTI-VENOM's Avatar
1988 Chevy MonteCarlo.
SBC 383 with all the good stuff.
*4 bolt (010) race preped block.
*Callies crankshaft.std.
*Forged 4340 "I" beam rods. 6" w/ ARP 7/16 bolts.
*Probe Industries forged SRP pistons w/ floating tool steel pins.
*ARP main/head studs.
*SFI balancer/ TCI flywheel.
*Internal balanced.
*Comp cams solid roller cam.(571/577-242/248@050.)(106cl-110lsa)
*195cc Airflow Reserch heads (2.02/1.60) 68cc = 10.6-1 copression. 7/16 studs w/roller rockers.
*Edelbrock airgap intake.
*750 dp Mighty Demon carb.
*MSD billet distributor and 6AL box.
*Milodon stroker oil pan.
*Hi torque mini starter.
*Hooker super comp headers coated.(1-3/4).3" dual ehaust w/ X pipe,Hooker aero chamber mufflers.
*Aluminum radiator.
*Aluminum water pump.
*Holley mech. pump. w/blue electric helper.
*Sumped gas tank.
Ken Wells built TH400 street/strip.
*TCI Street fighter 3000 stall for nitrous.
*3" drive shaft w/hd joints.
*G-Force cross member for dual exhaust.
*BMR drive shaft loop.
*Trans. cooler.
8.5" 28 spline rear.
*Eaton posi.(New). 3.73 ratio.
*BMR adjustable upper and lower control arms.
Auto meter Pro Comp gauges incl.(Tach,oil,water,and fuel pressure w/isolator.)
Harwood 4" hood.
Car is an AC delete with proper box and ducting. Only has heater and defrost. Interior is in good condition. No rips or tears. No cracks in the dash. Consol is great,the lid IS NOT broke. Small wear on carpet near gas pedal. The weather seal around the windshield will need to be replaced. All the drivetrain from the motor on back is new and was installed at the end of May 03. I have only put 3800 miles on this combo.
This was built to handle alot of nitrous.(piston ring gaps and piston to wall clearance).
Still have most of the receipts.
White w/ maroon interior.
The car has been my daily driver, so it has the normal chips and scratches in the paint. It has a small rust
spot on the trunk lid near the licence plate. The hood was just painted. The car needs a little tlc,
and a nice set on aluminum wheels. Mechanicaly it's sound.
With no tune it went 12.34@111 at the track. Only three passes
so far.
$14,000 invested. Pics availible.
Located in Orlando.
$8500 or trade for 94-95 z28 of similar quality. A/C a must. Or ???
Old Nov 8, 2003 | 08:06 PM
n2omike's Avatar
What the...............
I think you have really lost it now man.
I.
What the.
Really?
I just dont know what to say.
I will just have to give you a call or something.
Old Nov 9, 2003 | 07:29 PM
ANTI-VENOM's Avatar
yup.
Yea I know.What can I say, I miss my Z.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
dalynchmob
Feb 19, 2015 07:20 PM
SStupid
West South Central
Nov 10, 2002 02:39 AM
Lt1 and Ls1
West South Central
Oct 9, 2002 02:15 PM
