clicking noises
Old Nov 6, 2003 | 02:02 PM
ShayTal's Avatar
clicking noises
Hey all,
i have these weird click noises from the rear when i make a turn (right or left).
they are not that loud, you'll need to be very quite to hear it.
any ideas ?
Old Nov 6, 2003 | 02:20 PM
nikkev's Avatar
Have you changed the rear fluid lately?If you have and didn't use any GM additive the try some GM rear posi additive.That will make the noise go away.If it doens't then you have a bad rear.....
Old Nov 6, 2003 | 02:54 PM
ShayTal's Avatar
what does a bad rear mean ? :-)
Old Nov 6, 2003 | 03:48 PM
Capn Pete's Avatar
I think by '99 most Z28's & T/A's had the Zexel Torsen rear end, which, instead of a clutch pack, uses little worm gears to act as the "limited slip" instead of the traditional posi rear ends. I think the noise you are hearing is probably associated with that Torsen unit, and it's nothing to be concerned about (I don't think?! ). When I had my car at the dealership a few months ago for a service, the SERVICE ADVISOR thought that there was something wrong with my car when he heard those noises in the back, but then one of the MECHANICS (who fortunately had a Camaro of his own) took the car for a drive and said that "clunking" noise (especially when you take off after turning a corner) was "normal". I think it may get a little quieter if you put in the GM differential additive, but it's not necessary for the function of the Torsen (it's intended for the Auburn clutch-type posi's).
Aaront810
Aug 29, 2020 09:34 PM
autoxr166
Sep 25, 2015 04:21 PM
Sep 18, 2015 03:46 PM
Sep 17, 2015 11:53 AM
