questions about my BLM, AFGS, and BPW readings
anasazi
11-01-2003, 11:17 AM
my car runs very rich most of the time, except at WOT generally. it will sometimes misfire (because of?) while running rich. at WOT my BLM's go to 128, however while cruising or sitting idle they are at 115'ish.
my BLM's at idle are 115'ish, however at idle my BPW's for both sides is about 2.6 - 2.7... is this normal? its running pig rich, you can smell it.
AFGS is between 6.0 - 6.7 at idle.
however, when the MAF is unplugged the BLM's go to 127 - 129, BPW's go to 2.98 - 3.08.
would this indicate that the MAF is bad?
i just replaced my injectors with some i baught off a guy who upgraded his (his had less miles than mine) and that fixed a leaking injector, which cleared up my hard-starts. o2 sensors are about 4 months old, brand new AC Delco from GM. MAF is stock as far as i can tell, still screened.
i have the datamaster logs of both runs (with and without MAF sensor), can someone check them out?
MAF plugged in:
http://anasazi.sytes.net/carscans/datamaster_MAF_pluggedIN.uni
MAF unplugged:
http://anasazi.sytes.net/carscans/datamaster_MAF_unplugged.uni
thanks!
