Hardest Hitting 10"?
Desolate_Flux
10-31-2003, 11:39 AM
I used to have a MTX 8000 DVC sub in the back in a MTX Thunderform, hooked up to my Viper 1200.1 amp - and it slammed hard as hell.
Now I want more. I want a better sub. I want a single, 10" to put out more than ever before.
Whats the hardest hitting 10" sub that I can hook my 1200 watts @ 1ohm up to, and slam away? That way when people look in my trunk and cant find the sub, they're like wtf?
x7x7
10-31-2003, 01:34 PM
Adire Brahma 10 or elemental design 10A. I believe the brahma has more displacement. Slap thta bitch in a properly built ported box and it should get pretty loud. Both drivers have great SQ also, the brahma would probably be your best bet.
firebirdude
10-31-2003, 06:18 PM
I'm gonna vote against either of the two mention subwoofer. Both are outstanding SQ subwoofers and have extreme excursion capabilities. But neither are really "loud". And that's due to the super low distortion levels. Desolate_Flux sounds like he is just after LOUD. And for that I would recommend the Kicker L7. If you have enough room, go with a single 12" L7 in a ported enclosure. With 1200WRMS, I bet you're around the 145db mark....
megabass
10-31-2003, 07:55 PM
But the real question is where are you wanting to put this sub? Are you trying to use a stealth or a different larger style box. I can tell you that the brahma 10 won't fit most stealths because the magnet is too large. But if you were going to try a fiberglass stealth, then you have more options--like a 10W7:cool: But if you're on a budget and don't mind a bigger box, then the ported L7 as mentioned would get pretty loud.
Desolate_Flux
10-31-2003, 10:27 PM
I'm aiming to fit it in a stealthbox in the driver side... ;)
firebirdude
11-01-2003, 12:07 AM
Originally posted by Desolate_Flux
I'm aiming to fit it in a stealthbox in the driver side... ;) Ouch. Well, I still vote single 10" L7.
CrAkD X 95TA
11-01-2003, 01:02 AM
i vote the Power HX2 rockford 10" its a good medium between spl and sq 1000w rms 2000w peak....I have 500w running to it and it SLAMS u hook up 1000w to it and youll prolly have to hold on for dear life lol....you need either a passenger side stealth or a fiberglass driverside....if u find a fiberglass driverside at a good price lemme know im looking to add a second one to my system without spending $300 for the box.
Desolate_Flux
11-01-2003, 01:18 AM
Will a single 10" L7 fit in the driver side?
Who makes a good enclosure I can use? Subthump.com
The MTX one?
Thanks in advance
PaulN64
11-01-2003, 01:57 AM
not in the same league, but my Lightning Audio Strike 10.2.4 did hit 139.4db on the dash w/ a 300wrms Phoenix Gold amp. I just switched over to ID V3 sub and the ID seems like it's going to hit harder than the LA...but that's just from my personal experience.
Eliminator
11-01-2003, 09:17 AM
Doesnt the sound all depend on the box it was put in?? I heard 2-10" jensens hit really hard in non-ported box.
97FormulaWS-6
11-01-2003, 09:37 AM
yup, the enclosure makes ALL the difference... a awesome sub in an enclosure not built for it (specification wise) will sound worse than a crappy sub that's in a box built to it's specs...
IE: An unnamed friend of mine has a pair of HX2's in a box that he just bought and mounted them into, and it sounds, ok... pretty weak for 2 HX2's though, even with like 800 Wmax going to them... but I built a ported box with 2 MTX Thunder 3000's (Their lowest models like 5 years ago) that was built to spec and tuned for the subs. I'm only feeding the subs about 100W max each (WAY underpowered, GF doesn't have the $$ for a larger amp), and they POUND... they hit nearly as hard as my 2 Kicker S12L7's in a subthump sealed deep-well box. Part of that has to do with the sealed Vs ported issue.. but it shows that the enclosure CAN/DOES make a huge difference...
I'm actually going to try to find a better sub next spring that will do better in my well-box... The Kickers need a little more breathing room... They're probably going to end up in a ported enclosure in the new truck I'm buying in spring... then they should come alive, especially with the 1600Wrms I'm feeding them...
rthompson
11-01-2003, 05:46 PM
i would wager that the 10 A or Brahma 10 would get louder in the sealed stealth box and sound WORLDS better than the L7 ten. They both have a LOT more linear displacement, not that it has to be linear to get loud, but if you want it to sound good while getting loud you gotta have it.
x7x7
11-01-2003, 08:26 PM
The Brahma and the elemental A series 10 both displace more than the L7. The brahma displaces the most followed by the A and then the L7. Displacement=LOUD.
The A and the brahma will sound much better than the L7 in a small sealed enclosure and be louder given enough power.
firebirdude
11-01-2003, 09:26 PM
The A and the brahma will sound much better than the L7 in a small sealed enclosure and be louder given enough power. Displacement figures aside for a second....... answer me this..... have you personally heard either of these subs?
NAVY01Z
11-01-2003, 10:26 PM
Image Dynamics ID MAX 10
Phoenix Gold Titanium Series (although the magnet might be too
big)
Diamond Audio HEX 10-that's the old model. Not sure what they
renamed it.
Crossfire BMF 10
The ID MAX is the best sounding LOUD sub I've heard in a long time. 1000 watts rms. Great sub. Absolutely buries the
W7(:barf:). Ten times smoother than the Power HX2s.
x7x7
11-02-2003, 04:38 AM
I've heard L7s...12s and10s, a brahma 15, eclipse aluminum 15, etc.
There's no replacement for displacement. If you want SPL it's pretty logical to look at displacement. You want to move as much air as possible.
96ssz28#395
11-04-2003, 03:19 PM
I would say that the MA Audio Kore 10 will smoke every sub talked about on here it will hold 10,000 watts peak power and 5,000 watts continous. Given the right enclouser size with lots of power will flat do some damage. check them out at. www.maaudio.com trust me i have done car audio stuff for over 10 years.This is one of the if not the hardest hitting and loudest subs you will hear today. and there 12`s and 15`s in Kore`s are straight insane.you might find a hard time getting them but are well worth the wait for them.
96ssz28#395
11-04-2003, 03:40 PM
Also on the. www.maaudio.com site they only show the Kore 15`s and 18`s but the Kore 10`s and 12`s are rated the same 10,000 watts peak power and 5,000 constant. If you deside you like them and want that kind of sub.and have trouble finding them E-Mail me and i will try to help you out.Mike.
x7x7
11-04-2003, 04:47 PM
I don't think the Kore is made in a 10. Anyway, the XL 10 is the only one a see that would suit his needs. It still has less Xmax (the MA audio has 26mm peak to peak while the brahma has 28mm one way) although MA audio doesn't give out the driver's Sd I doubt it's much different from the brahma.
So the brahma still has more potential to get louder and will sound MUCH better doing so.
Just out of curiousity have you even heard of any of the drivers we're talking about?
brain
11-04-2003, 04:55 PM
Probably won't fit where you want it, but I would go with a JLW7. Best speaker on the market. It is expensive, but you get what you pay for.
96ssz28#395
11-04-2003, 08:38 PM
Just out of curiousity have you even heard of any of the drivers we're talking about? Yes they do actually make 10`s and 12`s in the kore line up. In fact yes i am very up to date on all the products talked about here. Including some not mentioned in this post.As a U.S.A.C. Offical judge. This past year i would say that the Kore Line up has much.In terms of bang for your buck. to offer. The down fall being you need a very high powered very low ohm capabile amp with very clean power. like a U.S.amps or even MA`s own amps. Although U.S. amps has a much better T.H.D. rate.Everyone has there own personal prefrance. As to what they like best.This is just what i personaly have noticed in this years U.S.A.C. shows last year it was Mattis and JL next year.It will be someone elese as it always is.My advise to the member wanting a hard hitting 10. Is go out and look at all that is out there for your best needs.Do not just jump at the one thing that a car audio sales person trys to sell you. As you may find that something half the price will suit your needs much better. good luck in whatever you deside. Thanks For Your Time. Mike...
NAVY01Z
11-04-2003, 09:31 PM
So what do you think about the ID MAX 10?
96ssz28#395
11-04-2003, 09:56 PM
Originally posted by NAVY01Z
So what do you think about the ID MAX 10? I think Image Dynamics all in all is a very good product. Also does not take alot of power to make there products scream. Case in point being mid`s and highs. However many places around this area try to sky rocket there prices. Which makes many people pass them up.You would be blown away if you really knew the mark up some places have in the car audio market. it is very common to see 200% mark up. in the install parts alone. Wire,fuse blocks,Encloseures, RCA`s,ect.
x7x7
11-05-2003, 02:29 AM
Why is the Kore 10 and 12 not listed on their websites? Why don't they give out their T/S parameters? I hear the Kore subs are one note wonders geared fully to SPL, they also don't handle as much as they claim. For their price there is much better out there. I haven't heard one so I can't say for sure but from what I've read they're not the greatest.
BTW, that does THD have to do with anything????? Especially in and SPL environment???? :confused: :confused: Please explain.
96ssz28#395
11-05-2003, 04:39 AM
BTW, that does THD have to do with anything????? Especially in and SPL environment???? :confused: :confused: Please explain. The reason why 10 and 12 Kore`s are not listed on the web site. Is because it has not been updated yet. Also the Kore line up is still a realatively new line.Look for it in the updated site due anytime. Also select authrized MA Audio dealers will have the info you are looking for. I can tell you first hand that i have personally seen the Kore 12`s take over 4,500 watts of power.To each driver and Loven every bit of it. As for the THD comment. Everyone knows the cleaner the signal. through out the whole system the better it is reproduced. Case in point U.S. amps has one of the best T.H.D. rates out there.0.009 T.H.D.Which makes Kore`s and U.S. Amps a good combo. As most amps that can produce the power needed to make the Kore`s work as designed. Have a high T.H.D. rate.Thus sound quality will suffer along with over all performance. With loads of power to boot. In U.S.Amps with most of there entry level amps being 1 ohm stable.Also a great many that can take 1/4 even 1/8th ohm loads.In my oppion would make this a great combo.The down fall is Price wise they are to expensive for most. But are top of the line type amp`s for pro or consumer even entry level performers. Thanks For Your Time. Mike...
x7x7
11-05-2003, 01:49 PM
THD is not really a useful specification. I've yet to see an amplifier for sale that had a THD high enough to be heard by the human ear. Have you? Maybe possibly a Jensen amp or pyle but who really uses those anyway? Here's some info that might interest you:
Total Harmonic Distortion:
When an amplifier is driven with a signal, the output of the amplifier is an amplified version of the input signal PLUS any distortion created by the amplifier. All amplifiers and signal processors add distortion to the signal. The levels of harmonic distortion in a high quality amplifiers are sooooo far below audibility that they are basically of no concern. When someone tells you that one amplifier is definitely going to sound better because its THD is rated at .002% vs an amp with .05%, you can be pretty sure that he doesn't know what he's talking about. Many people believe that THD below 1% is not audible and I believe they're probably correct. The fact is, especially in an automobile, the amplifier is the least of your worries. Speakers used for mids and highs commonly produce between 1% an 5% THD and for subwoofers the numbers can easily reach 10%. This doesn't even take into account all of the resonances of all of the plastic and metal panels in the vehicle.
http://www.eatel.net/~amptech/elecdisc/thd.htm
There's even a link to a sound file with noise added to it if you want to see for yourself.
Also, THD is something that you really don't have to worry about for SPL, who cares about how it sounds when you're in an SPL competition, you just want it as loud as possible. The bottom line is THD is not really a concern in car audio as long as you buy a decent quality product, even still the junk won't have an audible level of THD.
Do you by chance have the T/S parameters for the Kore series? I would love to take a look at em if possible. I'm curious to see how these model up.
96ssz28#395
11-05-2003, 02:50 PM
The reason why 10 and 12 Kore`s are not listed on the web site. Is because it has not been updated yet. Also the Kore line up is still a realatively new line.Look for it in the updated site due anytime. Also select authrized MA Audio dealers will have the info you are looking for. I can tell you first hand that i have personally seen the Kore 12`s take over 4,500 watts of power.To each driver and Loven every bit of it. As for the THD comment. Everyone knows the cleaner the signal. through out the whole system the better it is reproduced. Case in point U.S. amps has one of the best T.H.D. rates out there.0.009 T.H.D.Which makes Kore`s and U.S. Amps a good combo. As most amps that can produce the power needed to make the Kore`s work as designed. Have a high T.H.D. rate.Thus sound quality will suffer along with over all performance. With loads of power to boot. In U.S.Amps with most of there entry level amps being 1 ohm stable.Also a great many that can take 1/4 even 1/8th ohm loads.In my oppion would make this a great combo.The down fall is Price wise they are to expensive for most. But are top of the line type amp`s for pro or consumer even entry level performers. Thanks For Your Time. Mike... Please read again if you did not understand and as said in your own statment. Subs have a greater rate of T.H.D. As much as 5 to 10% trust me unless you just don`t have an ear for it you will hear distortion at that level.Also note that T.H.D. can happen at all levels of the spectrum from 20 to 20,000Khz which is all most humans are able to hear anyway not just one set bar note.as noted in the web page you have shown. So i would say that web page is very missleading to people. Distortion at high power levels.Can even cause small and large driver failure in the voice coils or spider area.I also believe that you may misunderstand what points i am trying to point out here. Because there is a very fine line between SPL vechiles and sound quality vechiles. Which has a much greater stage area in imageing such as heigth and width. The real competition such as the ones you see in U.S.A.C. Try there very best to meet that fine line. All in all. You are either one or the other.I would suggest you go to your local Autherized Ma Audio dealer or just E-mail Ma Audio for accurate Q and xmas questions for the Kore line up Thanks For Your Time........ Mike..
x7x7
11-05-2003, 07:57 PM
:rolleyes:
Yes, I have no idea what you're talking about, excuse my complete ignorance. I'm sorry Mr.U.S.A.C. Official judge who seems to not know what he's talking about and goes off talking about who knows what and forgets the task at hand. Go on thinking that you can hear .1% THD and that a THD over .009 will cause spider problems. :confused:
I really hope you're not really a USAC judge because if you are it's pretty sad that their judges are so ignorant.
What's this....? http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=1;t=021481#000000
What's that richard clark says? That's what I thought. Seems you're the one that doesn't understand. About the only thing I don't understand are your posts because your grammar and sentence structure is that of a 10 year old.
Anyway guys, sorry for going off in a different direction with this topic. I just wanted to point out that THD is the least of your worries at this point (and that 96ssz28#395 is talking out of his ass). I hope this thread has helped you to decide which driver to go with next. :)
96ssz28#395
11-05-2003, 11:02 PM
I do believe you need to first know WTF. You are talking about.As your so called buddy MR. Clark Said himself nothing below 3%. But as you stated in a past post here. Through the Subs this will increase to More Than 10% very easy and being the most of your power from the amps is High power usage to your subs you most likely will hear this on a low end amp. Like Your Buddy MR Clark Says As Well.Also let`s not forget him saying that you want to make sure that you have a amp that dose not run out of steam in the upper power levels. Which means try to get a amp that can do this efficently. thus strong signal, clear signal, and try to keep the T.H.D. to a min. This is why i was talking about such amps as the U.S. Amps line up. They are able to give you loads of power at a very low ohm load. Meaning 1 ohm and lower. With a very low T.H.D. Rate. So stop trying to turn my post around to say what you want them to. Open your mind up guy there are products out there that will blow you away. and some people have never even heard of them. As i was trying to openly let this guy who posted this thread know to look at all options before deciding what to get.Don`t just jump at the first thing a car audio sales rep wants to throw at you. Thanks For Your Time. Mike.
x7x7
11-06-2003, 03:50 AM
LOL. So hard to make sense of this but I will try.
Sentence Structure Grammar <-------You need em
What's this about high power usage? Are you talking about current draw? What does that have to do with anything? You want and amp that's efficient? Really, well I hate to break it to you but the efficient amps are the ones that are Class D and have higher THD ratings althought still inaudible, Class A/B (like your USAmps) are less efficient but have lower THD ratings. Efficiency has nothing to do with THD.
Also, Mr.Clark is refering to you having enough power to drive your load. If you're trying to run an MA audio kore 10 with a 300W amp with a THD rating of .000001% you're obviously going to clip the amp, this will increase the distortion hugely because amplifier THD ratings are measured when the amp is still putting out clean power (no clipping) when you start clipping the amp you start to increase THD greatly. Bottom line: have enough power for what you're running so you don't need to clip the amplifier.
I think most of the monoblock USAmps are one ohm stable. I highly doubt any of them would work well below 1 ohm without modification. Lots of amps are 1 ohm stable, big deal. My Cadence Z7000 puts out 1500W RMS@1ohm.
Why on earth would I want to turn around what you say? I read what you say and respond. What have I changed around???
I'm looking at products on the internet, and buying products from companies I have never seen in cars around here before. How am I not opening my mind?
96ssz28#395
11-06-2003, 12:57 PM
I would say that the MA Audio Kore 10 will smoke every sub talked about on here it will hold 10,000 watts peak power and 5,000 watts continous. Given the right enclouser size with lots of power will flat do some damage. check them out at. www.maaudio.com trust me i have done car audio stuff for over 10 years.This is one of the if not the hardest hitting and loudest subs you will hear today. and there 12`s and 15`s in Kore`s are straight insane.you might find a hard time getting them but are well worth the wait for them. Accept someone`s oppion other than yours.
96ssz28#395
11-06-2003, 01:03 PM
Yes they do actually make 10`s and 12`s in the kore line up. In fact yes i am very up to date on all the products talked about here. Including some not mentioned in this post.As a U.S.A.C. Offical judge. This past year i would say that the Kore Line up has much.In terms of bang for your buck. to offer. The down fall being you need a very high powered very low ohm capabile amp with very clean power. like a U.S.amps or even MA`s own amps. Although U.S. amps has a much better T.H.D. rate.Everyone has there own personal prefrance. As to what they like best.This is just what i personaly have noticed in this years U.S.A.C. shows last year it was Mattis and JL next year.It will be someone elese as it always is.My advise to the member wanting a hard hitting 10. Is go out and look at all that is out there for your best needs.Do not just jump at the one thing that a car audio sales person trys to sell you. As you may find that something half the price will suit your needs much better. good luck in whatever you deside. Thanks For Your Time. Mike... Again just trying to give helpful advise
96ssz28#395
11-06-2003, 01:22 PM
The reason why 10 and 12 Kore`s are not listed on the web site. Is because it has not been updated yet. Also the Kore line up is still a realatively new line.Look for it in the updated site due anytime. Also select authrized MA Audio dealers will have the info you are looking for. I can tell you first hand that i have personally seen the Kore 12`s take over 4,500 watts of power.To each driver and Loven every bit of it. As for the THD comment. Everyone knows the cleaner the signal. through out the whole system the better it is reproduced. Case in point U.S. amps has one of the best T.H.D. rates out there.0.009 T.H.D.Which makes Kore`s and U.S. Amps a good combo. As most amps that can produce the power needed to make the Kore`s work as designed. Have a high T.H.D. rate.Thus sound quality will suffer along with over all performance. With loads of power to boot. In U.S.Amps with most of there entry level amps being 1 ohm stable.Also a great many that can take 1/4 even 1/8th ohm loads.In my oppion would make this a great combo.The down fall is Price wise they are to expensive for most. But are top of the line type amp`s for pro or consumer even entry level performers. Thanks For Your Time. Mike... Again just simple info. Note as well U.S. amps was the first car audio amp on the market to have a 1/2 ohm stable amp wayback in 1988.In compatations today are considered to be one ofthe best amps out there. www.usamps.com see for yourself.
96ssz28#395
11-06-2003, 01:46 PM
Please read again if you did not understand and as said in your own statment. Subs have a greater rate of T.H.D. As much as 5 to 10% trust me unless you just don`t have an ear for it you will hear distortion at that level.Also note that T.H.D. can happen at all levels of the spectrum from 20 to 20,000Khz which is all most humans are able to hear anyway not just one set bar note.as noted in the web page you have shown. So i would say that web page is very missleading to people. Distortion at high power levels.Can even cause small and large driver failure in the voice coils or spider area.I also believe that you may misunderstand what points i am trying to point out here. Because there is a very fine line between SPL vechiles and sound quality vechiles. Which has a much greater stage area in imageing such as heigth and width. The real competition such as the ones you see in U.S.A.C. Try there very best to meet that fine line. All in all. You are either one or the other.I would suggest you go to your local Autherized Ma Audio dealer or just E-mail Ma Audio for accurate Q and xmas questions for the Kore line up Thanks For Your Time........ Mike.. Again just some advise as to who you can find out better info from
96ssz28#395
11-06-2003, 02:00 PM
I do believe you need to first know WTF. You are talking about.As your so called buddy MR. Clark Said himself nothing below 3%. But as you stated in a past post here. Through the Subs this will increase to More Than 10% very easy and being the most of your power from the amps is High power usage or current draw from your subs or the amp it self. You most likely will hear this on a low end amp. Like Your Buddy MR Clark Says As Well.Also let`s not forget him saying that you want to make sure that you have a amp that dose not run out of steam in the upper power levels. Which means try to get a amp that can do this efficently. thus strong signal, clear signal, and try to keep the T.H.D. to a min. This is why i was talking about such amps as the U.S. Amps line up. They are able to give you loads of power at a very low ohm load. Meaning 1 ohm and lower. With a very low T.H.D. Rate. So stop trying to turn my post around to say what you want them to. Open your mind up guy there are products out there that will blow you away. and some people have never even heard of them. As i was trying to openly let this guy who posted this thread know to look at all options before deciding what to get.Don`t just jump at the first thing a car audio sales rep wants to throw at you. Thanks For Your Time. Mike. x7x7 proved that you are not totally right.Even from quotes your own Mr.Clark says.
96ssz28#395
11-06-2003, 02:17 PM
x7x7 seems that most of your oppions are from hear say and mag quotes. Not proven real world compatation facts.Like i have personaly seen and had to judge myself. At a real world U.S.A.C. meets.Just face the fact my oppion differs from yours and leave it at that. Thanks For Your Time....... Mike.
x7x7
11-07-2003, 04:47 AM
What have I said that wasn't right? I stated all the facts.
FACT: you will NOT hear an audible difference between an amp with a THD rating of .009 vs. a THD of .1 unless either amp is driven to clipping.
FACT: THD ratings have NOTHING to do with spider problems unless the amp is severly clipped in which case THD ratings are way higher.
FACT: Many amplifiers are 1 ohm stable.
I never said USAmps were ****ty, they do make quality products. I didn't even say that the kore sub was ****ty, it just has less displacement than the brahma.
I'm just pointing out that your technical knowledge is lacking.
Anyway, this is my last reply. There's no point in replying to you if you don't understand what I'm saying.
96ssz28#395
11-07-2003, 10:07 AM
Yes I do totally understand what you are trying to say.Fact is i disagree with what you are saying. On the main subject i was refering to which was. Subs and Amps to power them. Fact. This is where most of the amplafied power in a car audio system is consumed. Fact.This is also where the highest levels of T.H.D. Can come from.Fact. It is very easy to have more than 10% T.H.D. In This Area of the system. Fact.This can be heard at that level.Fact. Even more so from a low end Amp. Fact.This was the reason why i even mentioned U.S.Amps as they can give you loads of power at a very low T.H.D. Rate.Fact.In high power systems. Higher levels of T.H.D. can occure. In the Sub area at such a rate as to even cause Sub failure. Fact. Such as burnt voice coils or torn spiders.I have seen this happen many times at U.S.A.C. meets.x7x7 just face facts your oppions are not the only ones.As i stated before my oppions are differant from yours. Leave it at that. Thanks For Your Time. Mike.
x7x7
11-07-2003, 02:13 PM
:rolleyes:
You lack technical knowledge and it really shows. You also lack an education. :p
This thread is no longer helping anyone. Byebye. :cool:
CrAkD X 95TA
11-07-2003, 03:30 PM
haha its funny how the guys on this site are sooo much more mature then the rest of the web i post on about 3 other msg boards besides this one (non-car related) and they all fight like cats and dogs what happened above is about the nastiest it gets here at camaroz28.com props guys for being adults about disagreements lol
