HeavyChevySS
10-30-2003, 11:58 AM
Does anyone have a picture of a dyno print out of a nitrous engine run without using the nitrous?
Reason being, I ran my Chevelle on a chassis dyno last week without using the nitrous. The engine is setup for nitrous but I am unsure about the exact specs on the camshaft. I basically want to compare my dyno results with someone elses and see if my results are what I should expect or if they show a problem with the engine.
thanks.
Heavy
kmook
10-30-2003, 12:02 PM
I dont see that you've tried this in the nitrous forum yet. Let try there as that should yeild the most results. Moving...
LPEdave
10-30-2003, 12:29 PM
Here's mine: http://www.go-fast.org/z28/photos/nitrous/n2odyno.gif
You'll see a stock LT1 dyno, then my 383 NA, then the 383 with about 175hp of nitrous.
Dave
My84Z
10-30-2003, 05:47 PM
http://community.webshots.com/photo/76465805/86644317dnzGqc here's mine froma couple mods ago
HeavyChevySS
10-31-2003, 12:21 PM
thanks kmook !
Those dyno results are nice, thanks for sharing.
My N/A dyno sheet looks nothing like you guy's N/A runs, both HP and TQ were alot different. Do you guys have NITROUS CAMS in your engines or are they regular cams? cause I am really looking for dyno results from a nitrous engine off the spray.
I am getting my webspace setup to host some pics. Then I can share my dyno results with you all.
My84Z
10-31-2003, 12:56 PM
thanx my car is a ls1. On that chart i had a cat back lid and tb. and nitrous on the 100 shot and 150 shot.
'94 Bad A Z28
11-02-2003, 02:48 PM
Dave
What kit are you running, those torque numbers seem very low for a 175 shot.
LPEdave
11-02-2003, 03:54 PM
Not a kit, just parts. But NOS Cheater solenoids, if that helps. What kind of torque gain would you expect?
Dave
rjames
11-07-2003, 10:30 PM
Looks like my old car when I got it done except my fuel program was set up too rich and that will cause a torque drop.
: new link below:
HeavyChevySS
11-08-2003, 08:11 AM
rjames, those links don't work.
says "forbidden access"
rjames
11-08-2003, 10:49 PM
Sorry bout that they worked when I posted them .
But click on the link here and go to album titled "Newest pics " they are in there.
Rob
http://community.webshots.com/user/rjjames1
