Here's how I deleted my ABS. Makes for an 8 pounds weight saings.
http://www.mustangmods.com/data/440/absdel.jpg
Email me if you would like fitting part numbers, source and pricing.
larry98@ev1.net
Word of caution. Don't use standard brass fittings. They may not be rated for the pressure requirements of a braking system. The fittings I used are pressure rated the same rating as the tube. In 3/16" and 1/4" tubing these fitting are rated up to 9600 psi.
chuck 10-28-2003, 08:38 AM How are your brakes after the mod? I thought the ABS unit controlled the front-to-rear bias, or proportioning, on our cars.
chpmnsws6 10-28-2003, 08:51 AM Originally posted by chuck
what he said! i wanna know so i can do it also
I have made a few hard stops and I can't tell any difference. Not a panic stop hard enough to lock the tires but hard. I would say they work pretty much like all the cars before ABS was introduced.
The ABS system does not control front/rear proportioning under braking conditions where the potential for wheel lock-up is not present. ABS is only active during braking conditions where prevention of wheel lock-up is necessary.
autoguy 10-28-2003, 08:50 PM does 8 pounds really make that big a difference? the reason i ask is because i wouldn't want to risk my saftey for 8 pounds.... just my thoughts on the matter.
chpmnsws6 10-28-2003, 08:54 PM i personally don't like abs and so i dont want it in my car.....
Mike94ZLT1 10-28-2003, 11:06 PM I f'ing HATE ABS. It's almost caused me many accidents. The tires on our cars are wide and sticky enought that on a dry road they aren't going to lock up. In snow, yes but I don't drive my baby in the snow, thats what the lemans is for. Please post a list of what you need, how you do it, and does this set off any warning lights? Thanks!
Mike94ZLT1 10-28-2003, 11:08 PM Got anything on deleting ASR? :D
chpmnsws6 10-29-2003, 12:44 AM we are just doing things that make the car feel better to us
chpmnsws6 10-29-2003, 08:56 AM ^^^^ for me its not about weight savings but the weight takin out of the front end is a good thing!
Originally posted by whoa guy
i think its dumb to delete stuff......then again....im not all hardcore wanting to go fast. if i was....i sure as heck would drag out a 4th gen. old chevelle, 'maro or nova or somehting....not a new car.
Depends on whether you like seeing tail lights or win lights! I suppose you don't mind seeing red. Myself, I like that win light!
I don't feel my 98 is all that new and too, it's not my daily driver. I use it for racing only.
Definitely makes a difference! If you are a serious racer 8 pounds is a very good savings. If you like seeing red like "whoa guy" then leave it on.
ABS is certainly a safer way of braking during a panic stop. I am not recommending anybody remove the ABS, only a way of doing it for the serious racers. ABS is definitely safer to have on wet streets and/or otherwise slick streets.
Ken S 10-29-2003, 02:51 PM Originally posted by ss00
are you sure? I've heard that there is dynamic brake proportioning in our cars which is part of the ABS system, thats active all the time..
JIMS1999CONVZ28 11-05-2004, 04:29 PM Hi Larry,
I used the fittings you recommended on CamaorZ28.com and they worked great, thanks.
When I went to bleed the brakes; passenger rear first, I got hardly any fluid coming out! I had my son pump till he got a firm petal and release the bleed valve and just a small amout of brake fluid came out of the line an after a few of these pumps no air at all. (I was using clear line to bleed).
Then the Driver Side rear and the same thing!
Then on to the front PS (new calipers, turned rotors, new Hawk Pads) and it bled normally. First get the air out, then make sure it is gone and a steady stream of Brake fluid. Same for the DS front.
QUESTION: Did you get the same amount of brake fluid coming off the rear calipers?
This is a 1993 Z28.
Thanks,
Jim
Hi Larry,
This is a 1993 Z28.
Thanks,
JimlI didn't bleed the rear when I installed the race brakes/calibers. I bleed the front by opening the valve and allowing fluid to start running out. Didn't even have to pump the pedal and it was bleed. The fitting on the Aerospace calibers is right at the top and after drained they are good to go!
Glad the Swagelok fitting worked for you too. So many buy new hoses that cost $$$ which is not necessary. My fittings have been working for several months now without a leak!
i'll be doing this next summer when i step up to a 9" rearend (no 3-channel abs, so i might as well save myself the 8 lbs).
AronZ28 11-06-2004, 10:37 PM if all you do is go down the quarter mile and never drive your car on the street, I'd say its a great way to save 8lbs.
If you drive on the street, I don't think 8lbs is worth the extra stopping distance in those Holy Sh!t moments when somebody wrecks in front of you on the interstate. Especially if you drive in the rain all the time. I'd rather be .00001 second slower than dead.
Also, ABS sucks in the snow. But nobody with any sense drives their Camaros in the snow. If I ever move north, my winter beater will not have abs.
AL SS590 M6 11-07-2004, 04:44 AM Nice post but not engine related.
I deleted all the "you're dumb to remove it" posts. This thread is about how to do it, not whether to do it.
Thanks for the info. I'll be deleting mine when I get the 12 non-ABS rear with spool.
JIMS1999CONVZ28 11-07-2004, 10:13 PM Thanks AL SS590 M6,
With a Moser Spooled rear (Like I have) the ABS will not work.
I guess some people that are reading my post are not reading my SIG; It clearly states "DRAG STRIP ONLY" and 4:56 Gears.
That pretty much sums it up. I have never heard of anyone running 4:56 gears on the street and I suppose OPEN HEADER could be a dead giveaway!
1993 Z28 HT, 383 6" rods, 12-1CR, Lloyd's heads/intake; 2.055" x 1.6" Manly SS valves, A4 8pt cage, Drag strip only; Turbo 400,w/ transbrake built by Kenny Wells, Turbo action Cheeta shifter. 4:56-1 Moser 9", Jet Hot LT's, open headers
crash4cyl 11-08-2004, 10:43 AM now the only kicker is adding a line loc for the serious racer!!!
Chris
Gearhead6s 11-15-2004, 10:55 PM can anyone give me the info on what parts were used with this delete? i emailed 8850 but i got no reply. i would like to do this delete my ABS soon and i could use the part list that he used.
JIMS1999CONVZ28 11-15-2004, 11:07 PM SS-300-3 Union Tee $18.80
SS-400-6-3 Reducing Union $8.90
These appear to be SS fittings, they have double compresson fittings and should be good to 3000 PSI
Swagelok
Alabama Fluid System Technologies Inc.
Pelham AL
205-988-4812
Sorry but I never received your email. I think JIMS1999CONVZ28 has pretty much spelled it out for you but here is a little more info and where I bought mine.
The lines are 3/16" and 6 mm. The 1/4" fitting works on the 6 mm. No flaring is required. These are high pressure compression fittings.
(1) Swagelok union tee SS-300-3 $17.90
(1) Swagelok reducing union SS-400-6-3 $8.50
http://www.mustangmods.com/data/440/fittings.jpg
Houston Center Valve and Fitting, 713 527 0233. It's the same as order number 97179975. Invoice number 401345.
Note: Order an extra set of ferules just in case your lose one. They are pretty small and easy to drop.
I would recommend a proportioning valve for the rear brakes. I have not installed one but it would be safer. I have tried a couple panic stops from slow speeds only and the car stops fine.
Let me know if you have anymore questions.
JIMS1999CONVZ28 11-16-2004, 10:04 AM Thanks,
From the company's letter head they have three locations, do an internet search and you will see where the closest warehouse is to you.
I would definately order extra compression sleeves/collars, they are small and as stated above if you drop one..... your screwed. Shipping was not cheep for me, $12.00, but labor and paperwork is expensive.
I did not use a porportioning valve, because I read where so many guys purchased them only to crank the valve wide open. When I bled the rear brakes I got very little fluid to come out at each 'pump up'. No air though!
If I had to do it over again I would ream out the inside of the pipes were I did the cut with the mini tubing cutter. Maybe that burr on the inside is causing some restriction, but lets face it. The front brakes do about 70% of the stopping anyway. I don't want the rear brakes to lock up. I also decided to repace the calipers (not retracting; the car sat 2.5 years outside) turn the rotors ( I never do that unless their warped) and got HAWK ceramic pads for extra stopping power. My set up looks like crap but it is a race car and it works... I think. I have not driven the car except off the trailer, on the dyno, and back on the trailer. I will know soon enough at the track after more tuning this Friday in Tampa if I will make it to Bradenton Drag Strip Friday Night.
Jim
