DEI alarm install
rs97
10-27-2003, 06:20 PM
i am in the process of installing my matrix rs2 using bfrankers alarm install web page. i bought the alarm on ebay, and I cant figure out what the 5 included relays are for, one relay has wires connected to the alarm "brain", i think on all the other ones the wires that come out of the relay are just cut off.
Javelin3o4
10-28-2003, 09:04 PM
the 5 relay system is for the remote start there should be a pink/pink w/ white wire, 2 reds, yellow, a ribbon cable that plugs into the alarm etc...
Red Wires (2) = 12v constant wire (heavy gauge)
Yellow = 12v switched wire
Pink = Ignition
Pink w/ White stripe = 2nd Ignition
Purple = Output to starter side of wire
remove the 2 30amp fuses until you are ready to test the system.
rs97
10-28-2003, 11:05 PM
thanks! that helps a ton
