adivanman
10-27-2003, 09:31 AM
I am looking at putting together a wet nitrous system for my EFI 502. The configuration of the manifold and throttle body is very similar to a LT1 except it uses an Alpha-N (like the ram jet crate engines) with no MAF, no SD, and no O2. The injectors are 36 pounds and fuel pressure is regulated at 42 pounds. I am looking for 200 HP.
A couple of questions for the EFI nitrous gurus....
1. My throttle body is a dual blade - should I use one or two fogger nozzles?
2. Can I inject right behing the TB or do I have to go through it?
3. What do you regulate the fuel pressure to for the fogger nozzles?
4. Does anyone have the HP and jetting per nozzle?
5. If I do use 2 nozzles, is it fair to double expected HP or are there losses to take into account like with dual carburetors.
I appologize for the simple questions. My history with nitrous has been carbureted plates and foggers. This engine and my MTI 396 LT1 are next in line for the bottle and I am trying to get a handle on the options.
Adivanman
Adivanman
