johnny o
10-25-2003, 06:04 PM
Do I need to change to a 94-95 knock sensor with the OBDII to OBDI conversion?
Change Knock Sensor with OBD2 -> OBDI Conversion?johnny o 10-25-2003, 06:04 PM Do I need to change to a 94-95 knock sensor with the OBDII to OBDI conversion? Injuneer 10-26-2003, 02:42 PM Yes... OBD-II KS is in the range of 100Kohm, OBD-I is 4.4Kohms. They are not compatible. madwolf 10-26-2003, 03:47 PM Originally posted by Injuneer Yes... OBD-II KS is in the range of 100Kohm, OBD-I is 4.4Kohms. They are not compatible. Not with the conversion kit he has... Johnny, the PCM has been modified to work with the OBDII knock sensor so you don't need to change anything. | ||
