johnny o
10-23-2003, 06:08 PM
I hooked the cable up to my laptop and started Freescan 2.10 but I am not getting any readings. I have it on COM1 with a 100ms delay but nothing seems to be showing on the daskboard or status page. Any ideas?
Freescan help!johnny o 10-23-2003, 06:08 PM I hooked the cable up to my laptop and started Freescan 2.10 but I am not getting any readings. I have it on COM1 with a 100ms delay but nothing seems to be showing on the daskboard or status page. Any ideas? Vomit God 10-24-2003, 02:06 AM I made my own cable and it works great.. :p Does your cable have the ALDL connector and everything? The only issue I've ever had was when using serial extension cables.. If the extension is cross wired (not a true extension), it wont give you anything.. The only other thing would be to ask you if the com port is enabled and properly functioning... You can plug a serial mouse into it and check that way.. DOOM Master 10-24-2003, 07:30 AM Do you have it set to interact? If you don't, it's not going to get any information. Get it to interact before you hit the start button. johnny o 10-25-2003, 12:05 AM I set it to interact and everything works good now :) thnx | ||
