Popping noise from drivers side front?
shwine617
10-22-2003, 06:04 PM
there is a popping noise coming from drivers side front end ever time i hit the gas a little bit hard. I jacked the wheel up and made sure it wasn't loose. I am not sure what it is?
thanks
IROC-T
10-22-2003, 06:40 PM
Strut barrings,or A-arm bushings.
Black6SpdTA
10-22-2003, 09:42 PM
Definitely in the front suspension. Try having someone lift up on the fender while you pinpoint the noise. Could very easily be the A-Arm bushings like IROC-T said. Good luck.
-Rippin
shwine617
10-22-2003, 09:46 PM
yea thats what i thought but i replaced all the bushings in the front with poly ones. I'll have to give it another check though, thanks!
Rice Killer87
10-22-2003, 10:01 PM
only happends when u hit the gas hard? sounds to me like its the tranny mount. check that
shwine617
10-22-2003, 10:08 PM
i had that too, i just changed the trans mount a month ago, so its not that. but i know what your talkin about cause like i said i had that problem , i thought the rear blew.
Chris Ja
10-23-2003, 01:37 AM
I would check the front sway bar bushing. Also check the motor mounts. Could be the pitman arms also as I had to replace one.
